Question about Reebok Rt1000 Treadmill Walking Belt
Squeel noise stopped belt
Stops and squeals with weight on it--worked twice after long storage
3 Suggested Answers
  • 218 Answers
SOURCE: rebox i run tread mill.Belt moving but if you put
drive belt is bad and needs replaced
Posted on Aug 13, 2010
lds_twin
  • 3 Answers
SOURCE: belt stops when placing weight
the belt in side the hood may be too tight. or the tsc may be set too low so take a small flat head after you remove hood and on the mother board should be an adjuster turn it while tread mill is safley position and turn it slightly
Posted on Jan 15, 2012
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
Squeeling noise on acceleration
a squeeling or winding ? alternator going out
Jan 12, 2013 | 2003 Dodge Caravan
2000 Mitsubishi Galant 4 cyl ES underhood squeal on right side
Be gentle with my rating. I am a long ways away. It sounds like a fan belt. You should pop the hood next time and see how it sounds when you have the squeeling going on. Fan belts will squeel until the get warmed up and then stop because the heat makes them grab the way they are ment too. Let me know, Raz
Apr 19, 2010 | 2000 Mitsubishi Galant
Squeeling belt, have replaced idler pulley, squeels when idling and turning with a/c on. Could it be the power steering pump?
Try using a very small spray of silicone spray on the belt next time you're hearing the squeal. If it temporarily stops, replace the belt. Check the p/s fluid level, if it's low it could cause the pump to make noise. Also if it's low, you have a leak, check all lines, connections and pull back the bellows boots on the p/s rack (if rack and pinion). Finally, pick yourself up a mechanic's stethescope, good tool for diagnosing accesory noises. Listen to all components while duplicating the noise.
Aug 04, 2009 | Ford F-150 Cars & Trucks
On a 2003 mitsubishi montero sport w/ 3.0 v6 a/c belt squeals
Your belt is loose (and it just needs tightening) or it is worn and needs to be replaced. It may look ok but they glaze over; all the little ridges get shinny and slip.
Jul 30, 2009 | 2003 Mitsubishi Montero Sport
Car makes a high-pitched squealing noise only while it is in lowest gear then stops once it gets up to 2nd or 3rd gear.
Check the belts for slippage and wear. If the tension is not correct, the belts will slip and create a "squealing" noise...moreso at higher rpms or on acceleration as you mentioned....That is the most common cause for a "squeel". I would check that first.
Good luck...i hope this helps fixya up.
Jul 23, 2009 | 1997 Honda Accord
Squealing noise
sounds like a loose belt!!
Dec 13, 2008 | 2003 Nissan Pathfinder
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Reebok Rt1000 Treadmill Walking Belt Logo
14 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
