Question about Sony Sound Forge Pro 10 for PC
164-S3PL-LB9Z-1X3B The authorization code - Sony Sound Forge Pro 10 for PC
Tip
Nokia secret codes
Here i have some secret codes for Nokia phones: On the main screen type: ¤ *#7780# : reset to factory settings. ¤ *#06# for checking IMEI (International Mobile Equipment Identity). ¤ *#67705646# : this will clear the LCD display (operator logo) ¤ *#0000# : to view software version. ¤ *#2820# : bluetooth device address. ¤ *#746025625# : sim lock allowed status. ¤ *#62209526# : display the MAC address of the WLAN adapter (this is available only in newer devices that support WLAN like N80) ¤ #pw+1234567890+1# : shows if sim has restrictions. ¤ *#92702689# : takes you to a secret menu where you can find the informations below: 1. Displays serial no. 2. The month and year of manufacture. 3. Displays (if there) the date when the phone has been purchased (MMYY). 4. Displays the date of last repair (if found) (0000). 5. Shows life timer of phone (time passes since last start). ¤ Enhanced Full Rate codec (EFR) activation. Increases signal strength, makes the signal reception better. It is also helpul in using GPRS when the service is not responding or working too slow. (note: phone battery will drain faster though). ¤ *#3370* : EFR deactivation. Phone will automatically restart. Battery life will increase by 30% because the phone will now recieve less signal from network. ¤ *#4720# : Half Rate Codec activation. ¤ *#4720* : Half Rate Codec deactivation. The phone will automatically restart. If you forgot wallet code for Nokia s60 phone, use this reset code: *#7370925538# (note: your data in the wallet will be erased) phone will ask for lock code (the default lock code is 12345). Press: *#3925538# to delete the contents and code of wallet or type: *#7370925538# on the main screen. This resets wallet code but you will lose all stuff in the wallet. ¤ *#7328748263373738# : resets security code (default code: 12345). ¤ Unlock service provider: insert sim, turn the phone ON and press volume up(arrow key) for 3 seconds, should say "pin code'', press ''c'' then press *. Message should flash, then press * again and 04*pin*pin*pin# change closed caller group (settings>security settings>user groups) to 00000 and your phone will sound the ''message tone'' when you are near a radar speed trap. Setting it to 500 will cause your phone to set off security alarms at shop exits ( works on some nokia phones)
on Oct 04, 2011 | Cell Phones
SERIAL NUMBER FOR SOUND FORGE 10.0
164-S3PL-LB9Z-1X3B
164-J0PB-PJVB-L2R3
Nov 25, 2012 | Sony Sound Forge 8.0 for PC
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Authentication code sound forge pro 10.0
serial for Sound Forge pro 10164-41PJ-D3SJ-1LK6
Authentication code
D1WYYWZG6-B60EB12XN-QYQXY55RQ-4KXSPFKXK-ZK5P7Y1TE-HZ5941KRY
Apr 16, 2012 | Sony Sound Forge Pro 10 for PC
Format my phone and reinstall OS because i'm having problems with applications and internet connection
Try the code *#7370# to hard format your phone then give the security code, if if doesn't work then try this: ¤ switch OFF the phone. ¤ press these keys together continueously *, 3, green key and ON/OFF button. The screen will show the formatting progress. ¤ take your hands off when the format completes. Rate my answer...
Oct 03, 2011 | Nokia N72 Cellular Phone
I cant change my phone language from hindi to english
Menu-->settings-->phone settings-->language then choose english.
you could identify the above mentioned path by icons.
Note :
hindi equalent for phone setting and language- are
phone setting ---?₪«?₪¼?¥??₪¨ ?₪¸?¥??₪Ÿ?₪¿?₪??₪??¥?₪¸
language--?₪­?₪¾?₪·?₪¾
thank you
Nov 29, 2010 | Nokia 2690 Cell Phone
Lost owners manual and need to program remote to Panasonic
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
Oct 22, 2007 | Hughes HRMC11 Remote Control
Sony Sound Forge Pro 10 for PC Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
