Question about Canon PIXMA iP4200 InkJet Photo Printer
Paper jam sensor?
I have just been given an almost new IP4300 printer but on firing it up the previous owner admiited that paper jam light comes on when in fact there is no paper in the tray he reckons it is a sensor problem anyone out there able to advise how to fix it? many thanks........... george fryer
  • gobzirk Nov 06, 2007
    I seem to have the same problem. I ran some lables thru and some came of - got stuck. I have removed the caught lables and accounted for them all but still says paper jam
    please help
  • 286 Answers
I should really make myself a copy of this text so I can just paste it when needed.
It would take too much detailed work to describe to you how to take the machines apart.
You have a piece or paper or other object stuck in the sensor, or you have a broken sensor actuator or a bent actuator.
You have to take the machine apart, find the sensor which is usually located at the back right where the paper starts going through to the front, and remove the object, paper or repair the actuator.
Posted on Dec 30, 2007
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Orange light flashes 5 times continuously on canon pixma ip4300
Orange light flashes if there is any issue with the printer. Please check all the hardware is functioning properly. Check if there is any paper jam. If printer cartridge is installed properly. Printing head is ok.
Dec 09, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma IP 4300 printer - 3 blinking panel lights indicate paper jam, however no paper jam is present. I turned off machine, pulled power plug, waited for 5 minutes, turned on printer, but problem did...
It is possible that the printer is having an error due to either a sensor fault ( optocoupler) in the paper detect section or a possible software issue.
So disconnecct printter, and uninstall the soft ware , the reinstall and then connecct printer to be detected and installed.
If the fault stays then the sensor must be checked.
Sep 11, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My printer error light is blinking 3 times saying that there is a paper jam but there is no paper in the machine
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
There's a small white light below the power light that's flashin.
In this case you may have to clear the memory of the printer or set the printer to default.
May 07, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
240 people viewed this question
Clive
Clive
old marine
old marine
