Miele softronic w3623
Technische foutmelding f63
5 Suggested Answers
SOURCE: miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Posted on Jul 03, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
  • 251 Answers
SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Posted on Jun 14, 2011
SOURCE: Miele fault F63
Just thought I'd add some feedback here which may help someone (March 2013). We have a Miele Novotronic W1613 washing machine which developed a "Technical Error F63". I contacted Miele, and they told me that this required a "PC download" to fix - basically, updating the software in the washing machine. If you look at the front of the W1613, just below the Start button is what looks like a little glass LED, labelled "PC". This is a fibre-optic link access to the washing machine's processor. Miele very kindly agreed to fix the machine free of charge (we were actually a few days out of the two-year warranty). The engineer used a suction cup to connect a fibre-optic link to his PC, and updated the machine's software. This solved the problem! Obviously, this is not the sort of problem that can be fixed by yourself...
Posted on Mar 18, 2013
How do I fix this myself: Miele Softronix W 1734. Reports Error: "F63" When I look up that error I get: "Contact Miele technician"
either the controller is not working or the inlet valve is bad .could also be the pressure switch that tells the machine when it is full enough
Jun 05, 2016 | Miele Washing Machines
On and off switch has Been pushed in slightly but still works Miele W3623 wash machine. Is it possible buy a new switch
replace the whole display panel or can buy the switch
Tony, It looks like Miele wants whole panel replaced on the washer.
Miele Customer Support Product Manuals Brochures
Mar 31, 2016 | Miele Washing Machines
Where can I get a service manual for dryer Miele softronic T 4422 C
Manual is normally hidden inside the case, either bottom right, or inside the console at the top.
Make sure all the vents and pipes to outside are clear of lint and obstruction.
Jul 28, 2015 | Miele Dryers
We cannot open the metal door of MIELE SOFTRONIC W3241.Faulty lightshowing all the time.
Turn off the power and wait for a couple of minutes, that should allow the door to open. You can find out what the fault lights mean by using Google and describing what your lights are showing.
Steve B
UK
Feb 17, 2014 | Washing Machines
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Dec 08, 2013 | Miele Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
Jun 05, 2011 | Miele W 4800 Front Load Washer
Hi,i have a washing machine miele w 3000 tech fault f63.what i can do?
Total Cost: (HKD)
1100 for the part
Jul 03, 2010 | Miele Washing Machines
Miele w3033 tech fault f63. what to do?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
