Question about HP CopyJet All-In-One InkJet Printer
Hp photosmart C3100 all in one
When printing a letter it cuts off the right margin....needing to move it over so the whole letter is readable....how do i do this....thank you
  • Anonymous Mar 08, 2009
    Same problem. Only way i've been able to solve it is to print Landscape instead of Portrait (on Page Setup). What a bummer.
    JM
Printer won't print from quicken file. no other problems with printing.
Posted on Jan 11, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Is it set for letter paper? sounds like it is A4 instead
Posted on Oct 11, 2007
SOURCE:
Where is the ink cartridge located on the HP c3140 and how to I get to it?
From the manual:
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 1
14 HP Photosmart C3100 All-in-One series
HP All-in-One overview
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridge
Jul 24, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
HP Photosmart 2610xi is printing but it does not keep the left margin aligned - it typically floats progressively to the right but sometimes wanders back and forth. Also about mid-way through each line...
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
Dec 31, 2009 | HP Photosmart 2610xi All-In-One InkJet...
HP photosmart 8250 is printing different margins
ok..do us a favor here..try a test page from printer selection panel. just to make sure it's not the printer..you may need to re install new printer drivers.
Nov 28, 2009 | HP Photosmart 8250 InkJet Printer
Hp 3210 photosmart Is it possible to print from black cartridge only,
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
Feb 20, 2009 | HP Photosmart 3210 All-In-One InkJet...
Printer will occasionally print incomplete document
Sounds like an issue with the bottom margin and/or footer if you are using a footer. Check the page setup and reduce the bottom margin.
Jan 24, 2009 | HP Photosmart C6280 Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Oki c3100
hmmm..did you check your margin settings in the print set up?
Aug 19, 2008 | OKI C3100 Led Printer
HP PHOTOMART C3100 SERIES ALL-IN-ONE
I can help you when you tell me witch printer you have.
Mar 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Dec 19, 2007 | HP Photosmart 7450 InkJet Printer
Open Questions:
See all HP CopyJet All-In-One InkJet Printer Questions
143 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
