Water trickles rinse cycle washer
I have a new Kenmore top load washer model W10338681(?)that has never worked right. When it fills for wash/rinse cycles the water trickles in. And it skips the rinse cycle completely. The only time it worked correctly was last week on 11/9/13. This is the second new washer that has done the same thing.
freetek
  • 5568 Answers
SOURCE: just a trickle of water during rinse cycle
You write that the water flows fine during the wash cycle; if you mean while the machine is washing, then it is the pump  making the water flow. You need to watch the water flow while filling for any cycle since it could be slow filling and not running.
Since the same valve(s) control the water intake during washing and rinsing, what you describe doesn't make sense. I suggest your remove both ends of both hoses and inspect them and the mating connectors on the machine for clogged screens.
If these are clear of any sediment, then the flow control valve is failing. This is located on the rear of the machine and the screw connections for your hoses are part of the valve body. This assembly is pretty easy to remove and replace, is a common and not very expensive failure.
If you are in the US, check to see if you have a Johnstone Supply in your area. They sell mostly wholesale to tradesmen but have never turned a private sale away and are far less expensive than dealers with pricing ranging from 30-50% of dealer price.
Posted on Oct 12, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Posted on Apr 25, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
Posted on May 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
No water pressure on fill.
Hi, If you have checked the screens in the mixer valve and there is nothing plugging it, then it is most likely the mixer valve.
I hope this helps. Please let me know and feel free to rate my response to you.
Thanks
Vic
May 20, 2009 | Kenmore 22422 Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Cold water in the rinse cycle of the washer just trickles
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
