Question about Stihl Bg 86c Handheld Blower Cylinder Bg86c
Bg86c spark plug change
How do I change the spark plug on my bg86c stihl blower
The tool you got with the unit for changing other parts
usually is a T shape and has two hex socket at the top of the T and the stem has a torx 10 or similar on it
is also used to change the spark plug
Posted on Dec 04, 2014
5 Suggested Answers
  • 2239 Answers
SOURCE: Stihl Leaf Blower no top speed model BG86C
If there is a spark arrester in the muffler outlet check this is not blocked with carbon.
Posted on Jun 10, 2012
  • 6468 Answers
SOURCE: Stihl Leaf Blower BG86c no top speed
take off the muffler and run it the screen inside it might be plugged and you can clean it off by opening the muffler
Posted on Jun 13, 2012
hunter19_46m
  • 7482 Answers
SOURCE: BG86C muffler Stihl Blower
Hi roberthoh288
Go to the following webpage and order your parts.
Please take time to rate me
Bud
http://www.jackssmallengines.com/
Posted on Oct 11, 2012
plink_plonk
  • 1807 Answers
SOURCE: bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Posted on Mar 16, 2013
Spark plug gap on stihl leaf blower shoulder strap
Tammy,buy your spark plug from Autozone,Stihl has a high mark up.2.40 from A.Z.
Aug 08, 2015 | Stihl Garden
Stihl blower won't spark.
check the key in the flywheel,any wear in the key can cause it to be out out of time and it will cause no spark at the spark plug.
Jun 06, 2015 | Stihl Garden
How to change flywheel on bg86c stihl blower
  1. Remove fan housing
  2. Remove spark plug and install piston stop.
  3. Remove flywheel nut.
  4. If flywheel is struck on use a puller. Stihl uses a knocker type puller that screw on the crankshaft and tapped by a hammer. Be carefully not the damage the crankshaft stud or the bearing.
  5. To install reverse the above skipping item 4. Just make the flywheel engages the slot in the crankshalf. The flywheel nut is torque to 17 nM or 150 in lbs. Don't over torque the nut or damage will occur to the flywheel.
Dec 16, 2014 | Stihl Garden
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Stihl bg86c blower. Quit running after abt twenty mins of good strong blowing. Didn't sputter or anything, just dead quit. Not getting fuel to cylinder. Checked filter,gas lines, took apart cleaned and put...
take it in for a carby rebuild
the rest is perfectly fine
if you have been using e-mix fuels , don't as it damages the delicate diaphragms in the carby
Jul 08, 2017 | Garden
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Will not prime-new bulb-new primer base have rebuilt carb
Maybe a problem with the 'connector' (item 4) as its the only way for fuel to pass in and out the fuel tank. Obviously assuming none of the pipes are leaking. Also check the fuel tank vent (item 2), these have valves in and can often perrish and leak to atmosphire. 3_2_2013_11_33_39_pm.jpg
Dec 19, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Hi roberthoh288
Bud
Sep 28, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Jun 09, 2012 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl Bg 86c Handheld Blower Cylinder Bg86c Logo
283 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
