Question about KitchenAid Kitchen Aid KPCG100OB - Burr Coffee Mill w/ 15-Grind Sizes, Die Cast M
Manual for KCG2000B1 coffee mill - KitchenAid Kitchen Aid KPCG100OB - Burr Coffee Mill w/ 15-Grind Sizes, Die Cast M
I recently purchased your mill & brew 12-cup programmable coffee maker. When I program it to come on in the morning, I wake up to water on my counter and a half a pot of coffee.
sad to tell you this but it is not our mill as we sell nothing nor do we know the make or model . return it to where you bought it if it isn't right
Mar 26, 2015 | Coffee Makers & Espresso Machines
Can I grind coffee in an electric grain mill?
Electric grain mills were not designed to grind up oily grains like coffee, you would be better off getting either a hand grinder or a coffee grinder.
Jan 23, 2014 | Kitchen Appliances - Others
Can I use a coffee grinder to mill grains?
You can although I have found that the coffee grinder doesn't mill the grains down to a fine enough powder for making flour though.
How do I clean my coffee mill/grinder (Models IDS50, IDS55, IDS57, IDS59)?
Clean your coffee mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Unplug your coffee mill.
  2. DO NOT PLACE THIS COFFEE MILL IN WATER. DO NOT IMMERSE THE BLADES OR MOTOR BASE IN WATER.
  3. Remove the coffee mill cover and brush. Wash both in warm sudsy water. Rinse and dry each thoroughly. The cover and brush are NOT dishwasher safe.
  4. Use the Built-In Cleaning Brush to sweep out excess grounds. Use a clean cloth or paper towel to remove any remaining grounds.
  5. Be sure to clean your coffee mill completely after each use.
  6. Do not try to oil or sharpen the blades. The blades are permanently lubricated and never need sharpening.
Sep 02, 2011 | Bunn NHB Coffee Maker
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
KitchenAid Kitchen Aid KPCG100OB - Burr Coffee Mill w/ 15-Grind Sizes, Die Cast M Logo
55 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
