Question about Toshiba Satellite Computers & Internet
I was on a private network, now its changed to public
I would like to switch back to a private network. I dont know how
  • 65 Answers
Delete your network setting and start again
Posted on Nov 17, 2013
  • Lee Crump
    Lee Crump Feb 10, 2014
    thank you. it worked
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to http://whatismyipaddress.com/ and it will tell you what your external public IP address is.
Mar 06, 2013 | E-Machines eMachines Desktop PC
Not getting wi Fi
  1. From the Homescreen, tap Settings.
  2. In Settings, tap Wi-Fi.
  3. Slide the slider to "on" to start your device looking for Wi-Fi networks. In a few seconds, you will see a list of all available networks (if you don't see the list, there may not be any within range).
  4. There are two kinds of networks: public and private. Private networks have a lock icon next to them. Public don't. The bars next to each network name indicate the strength of the connection - the more bars, the faster connection you'll get.
    To join a public network, just tap the network's name and you'll join it.
  5. If it's a private network, you'll need a password. Tap the network name and you'll be prompted for a password. Enter it and tap the join button in the bottom right-hand corner. If your password is correct, you'll join the network and be surfing the web. If not, you can try entering it again (assuming you know it, of course).
  6. More advanced users can click the arrow at the right of the network name to enter more specific settings, but the everyday user won't need this.
Oct 08, 2012 | Cell Phones
Router ar 410, wan port is eth0 with statick ip, public, and switch port 1 is on vlan2 with pirvate ip address 192.168.18.253. how tu add default route for acces to internet eth0 is connected on shdsl...
Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
Mar 01, 2011 | Allied Telesyn AT AR410 Router
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
Hi. How do I change my public network to a private one without knowing the password?
you need to set a password and this has to be done using the router web interface (192.168.1.X) find the default gateway of you computer - run ipconfig on command prompt will let you know the defaukt gatway - once you are loged in to that web interface - go to wireless section and enable the security as need - this will make your network as private.
router Web interface can be opened by typing just the default gateway on address bar of IE .
Oct 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Local access only.
You need to configure the router for internet access. If you are on Cable ISP, you need to do MAC Cloning. If you are on DSL ISP, you need to configure the router for PPPoE. Normally, the router's setup CD can guide on how to do it.
Oct 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
Two computers and printer dont communicate with workgroup swith
Do you have a router in front of the switch? Most ISPs only give you one or two "public" addresses. If you don't have a router in front of the switch, your computers and devices will not receive the "private" addresses they need to communicate with each other and the internet.
Jan 28, 2009 | Linksys EtherFast Workgroup 8x10/100 Mbps...
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Computers & Internet Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
