Question about Husqvarna 450 e-series 18" Chain Saw
Adjust bar oil flow - Husqvarna 450 e-series 18" Chain Saw
5 Suggested Answers
  • 615 Answers
SOURCE: no bar chain oil flow
I do not know how old the unit is but usually these saws get clogged often as result of wet plants with sand or dirt and they do clog the unit…see if you can take it to self car wash and pay few $$ to wash it and air pressure everything that if you do not have them LOL…I use this as it is the most cheapest way to clean my generators, garden equipments, etc. let me know..
Posted on Sep 15, 2009
  • 2239 Answers
SOURCE: Have a model#-137-husky.has it got
The pump is not adjustable, it is very unusual for them to over oil, the pump shaft can only rotate at the speed of the engine, it is calibrated to cope with a 15" bar, it is more likley it is leaking out of the oil tank.
Posted on Mar 18, 2011
  • 2239 Answers
SOURCE: How to adjust bar oil flow as bar heating up too
Not all Husqvarna models have an adjustable pump, if it is adjustable there will be a slot head screw either at the side of the sprocket, or just under neath the sprocket, there will be a small symbal of a drop of oil and a + and - sign.
Posted on Aug 22, 2011
MOTORWIZJ
  • 1339 Answers
SOURCE: THERE IS NO SCREW TO ADJUST BAR OIL ON MY 51 HUSQVARNA IT JUST COMES OUT WAY TO MUCH THERE IS NO SCREW TO ADJUST SERIAL NUMBER OF MY SAW IS 425-1275
try this click here .. been awhile since i worked on one. it is nice to have lots of oil, but should be same as a tank of gas .. jay the pool pump repair guy florida
Posted on Feb 03, 2012
How can I adjust the oil flow to the bar of chainsaw?
Look-up the UT-43103 IPL. There is no provision to adjust the oil flow. Suggest checking the oil lines for loose or broken areas; also could replace the oil pump. These are very inexpensive parts. here is a link to the parts list and source for the parts.
Homelite UT43103 Electric Chain Saw Parts
Dec 06, 2014 | Homelite Garden
How do i adjust the chain oil flow rate
to test if your oiler is functional remove bar and chain and start unit. if it drips oil with bar and chain off then clean the oil hole in the bar. if plugged it will prevent oil from reaching bar for lubrication of chain
Sep 16, 2014 | Garden
On the poulan 42cc chainsw how do i adjust the flow of bar oil
To adjust the automatic oil flow, Turn the chainsaw upside down. Turn the screw marked with a "+" or "-" toward the "+" sign. If too much oil is present turn the screw toward the "-" sign. Repeat the oil test and adjust as necessary.
Read more : http://www.ehow.com/how_7767305_adjust-bar-chain-oil-flow.html
Jul 01, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
HOW TO CONTROL THE OIL FLOW AND ADJUST THE CHAIN FOR AN ELECTRIC CHAIN SAW
The oil flow is not adjustable
Check the bar to see if it has something that looks like a flat head screw that you can turn, it is possible that it is equipped with an EZ adjust bar where you can make tension adjustments without loosening the cover. If not, loosen the bar nuts and use the tension screw on the back of the cover to make your adjustments.
Aug 31, 2011 | Poulan 14" Chainsaw
Can i alter oil flow to chaimac 436
Most hobby saws do not have an adjustable pump, if it is adjustable there will be an external screw close the the clutch and sprocket, would would not need to remove the bar and chain to acsess it.
Feb 12, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No oil flows to chain
Depending on your knowledge and experience -
1. Find your manual and check on maintenance routines.
2. If no manual avail - clean your saw and your bar.
Bar - oil holes clear, groove clean etc
Saw - locate where the oil pumps out - ensure any guides, holes etc are clean.
3. If saw gas manual oil pump adjustment screw -advance the flow
4 Drain the oil tank checking for dirt etc and if necessary clean tank with a little of your fuel.
5.Refill oil tank AFTER it is clean and dry.
6. Replace bar/chain etc and test if flow is better
If still no good you may need to repair/replace oil pump -not that hard to do but if in doubt take it to a reputable dealer.
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
I have a Poulan 20" chain saw that keeps leaking out the bar oil every time I put it in the container and store it. What causes this and can it be fixed by myself?
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Aug 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 450 e-series 18" Chain Saw Logo
27 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
