Question about Panasonic Audio Players & Recorders
Lock unlock my sc-xh170 - Panasonic Audio Players & Recorders
C2050 sc How to unlock the cell phone if it is locked?
You can call your carrier and tell them to give you an unlock code. Or from the seller.
Jul 10, 2014 | Samsung Cell Phones
Keys locked in trunk
Depending on the vehicle the rear seats may be able to come down, of course the the doors would need to be unlocked though. If the doors are locked as well all you need is a coat hanger and a wooden shim to unlock the door.
Apr 04, 2014 | 1992 Lexus Sc 400
No sound on USB
We regret to inform you the USB connection from an Apple TV will not provide you any sound. We recommend you connect the Apple TV with an Optical cable then place the home theater on the Optical input to hear sound.
Mar 15, 2014 | Panasonic SC-XH170 Dvd Home Theater System
Panasonic_sc_pt_170_displaying_locked
This unit has two locks for demonstration purposes so discs can't be stolen.
Eject lock:
With the unit powered on, press and hold stop button and power button on main unit for at least three seconds until it shows unlocked.
Function lock:
With the unit powered on, press and hold play button and power button on main unit for at least three seconds until it shows unlocked.
Hope this helps.
May 28, 2011 | Panasonic SC-PT160 Home Theatre Kit
I have a konica minolta N13656 camera and my SD card is locked and don't know how to unlock it
There is a small plastic slider tab on the left hand side of the SC card, looking from the top. Slide it toward the gold fingers to unlock it.
Feb 19, 2010 | Cameras
Loud continuous clicking noise from all 4 door locks,
Either 1) One of the door lock switches is stuck (the car is continuously trying to lock or unlock the doors, most likely in the "unlock" position); try to wiggle each door lock switch up and down (into the lock and then unlock position) to see if you can free the stuck switch. 2) More difficult to repair - the locking system's wiring harness has become damaged such that an exposed conductor is making contact with a metal part of the car (i.e. it's being grounded, which has the same effect as operating the door lock switch. Has any work been performed on this car recently, especially any door panels removed? Someone could have shot a screw through the wiring harness. If this is the nature of the problem, it may be a slow, tedious repair.
Jul 01, 2009 | 2001 Saturn SC
Power door locks going crazy
One of your door lock inside switches are bad.Find the one that doesn't feel right when you push it in either lock or unlock.The internal spring is broke causing the lock relay to keep try to lock or unlock until it gets hot & protects.
May 07, 2009 | 2001 Saturn SC
1995 lexus sc 300 driver door wont unlock
yes it most likley not the rods off handle and lock asy.
Apr 10, 2009 | 1995 Lexus Sc 400
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
