Question about Toshiba W522 VHS VCR
Toshiba w528 vcr tape eating
I recently cleaned the heads on my toshiba W528 VCR. Now everytime I put a tape in it appears that the vcr literally spits the tape out and it gets wrapped around pretty much everything. Did I mess something up and if so can I still fix it? Also do you happen to have a picture of what the inside of the VCR is supposed to look like to make sure I didn't mess anything up?
  • morgana47 Oct 09, 2007
    thanks, I have to admit I have no idea what I'm doing, but I put some WD40 on the little plastic axels where the three flat gears are, all the teeth are fine, and it appears to be working fine now, thanks for your help
    Novelist:
    Champion:
  • 254 Answers
Tape "eating" is usually caused by a no take-up condition, that is, the take-up spindle isn't being driven, and thus a certain amount of tape spools out inside the mechanism until the logic circuit senses an error condition and places the machine in an off or stop mode. Cleaning the head shouldn't cause this, assuming you knew what you were doing, and nothing was broken or bent in the process. Look down in between the spindles, and you will see an idler wheel which pivots between the spindles, depending if the mode is Rewind, Fast forward or play. This idler mechanism should pivot freely. If the grease is dried or sticky, or the idler is otherwise broken- gear teeth missing, etc. such must be corrected. If the idler needs replacement, one might be available from the manufacturer, or a parts supplier such as MCM Electronics.
Posted on Oct 08, 2007
  • Anonymous Oct 09, 2007
    A tiny bit of WD40 won't hurt, though if sprayed around indiscriminately a bad thing. My usual repair on a sticky mechanism is to disassemble, clean off all old lubricant, and relube with a suitable grease/oil. Singer sewing machine oil usually provided satisfactory results.
    Glad the VCR is working!!
SOURCE:
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
I have a Toshiba W528 VCR and am trying to hook up a Wii in the front panel Line 2 jacks. How do you switch the connnection to the Line 2 jacks without a remote?
With the up and down channel selector buttons. You will have to keep pressing either button till it shows AV (something IE 1 or 2 etc). Depending what it says on the front panel for the socket.
Recommend a universal remote if you can't get a new one.
Feb 06, 2011 | Toshiba W522 VHS VCR
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost remote on toshiba w528
You can select those to record with out the remote by setting the record timer to record. For example, if you want to record from one of those input channels on Friday 1 January 2009 at 9:00 to 11:00, it will allow you to choose that as an input channel in that program menu. If not, you will want to buy a replacement remote. VC-522 is no longer available, but VC-617 and other models are.
Nov 16, 2008 | Toshiba W522 VHS VCR
Vcr has started to eat tapes. Put tape in starts to run then stops.
I did not have a problem with a projector tv-it was a vcr. I took it apart-cleaned the heads and used compressed air to blow out the dust.
Nov 06, 2008 | Televison & Video
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Model W528
find your model number here, and the manual in Adobe Acrobat format http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/vcrct.asp
Jul 23, 2007 | Toshiba W522 VHS VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Toshiba W522 VHS VCR Logo
508 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
