Question about Garden
Air filter for Dynamac DY41 chainsaw
Any ideas for air filter for Dynamac DY 41 chainsaw? Carburettor make is Walbro
  • 2,760 Answers
If its a two cycle engine the only filter it really needs is a fine mesh brass screen over the intake , micro particulate dirt will go straight thru the carb and combustion chamber with no problems , four cycles they require a nice oiled foam filter that can be purchased new or made from a used bit of pkg foam and pair of sharp scissors , a squirt(not soaked) of bar chain oil into it and its good to go , as the carbs and cylinders will be affected more by small parts of dirt
Posted on Jul 17, 2015
  • 16 Answers
SOURCE: Chainsaw kills when I press the throttle
broken fuel pipe is a common problem
Posted on Nov 11, 2008
slohry
  • 87 Answers
SOURCE: Engine wont run.Stihl 028 chainsaw.
Remove and clean the exhaust port, muffler and spark arrestor screen. Also clean the air filter.
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Posted on Jun 04, 2009
  • 13 Answers
SOURCE: ignition coil
Here you go. If the price seems high there are likely several more to be found on this page. Good luck with it.
http://cgi.ebay.com/36-136-137-41-141-142-HUSQVARNA-SAW-IGNITION-COIL_W0QQitemZ270389321883QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef475a09b&_trksid=p3286.m20.l1116
Posted on Jul 16, 2009
  • 302 Answers
SOURCE: Husky 345 chainsaw will only run with choke almost
turn both carb adj. screws out 1 1/2 turns from bottom and then fine tune them with it running. the one marked L is for low speed and the one marked H is for high speed. hope this helps
Posted on Sep 08, 2009
How to clean air filter?
Hi Sharon!
If you have a paper air filter it will need to be replaced, rather than cleaned.
However if you have a foam air filter you can wash it in mild detergent and allow it to completely air dry and put it back into your chainsaw.
Here is a video about how to replace the air filter on a chainsaw, most are pretty similar, so if it's not quite the same brand as yours, it should give you the general idea.
Best of luck!
Replacing the Air Filter on RedMax Chainsaw
Chainsaw Air Filters I've also included a page to find replacement air filters for your chainsaw!
Sep 27, 2015 | Garden
Proper fuel mixture for Dynamac DY 51?
you would be safe to run a standard 25:1 mix 200ml of 2-stoke oil to 5 liters of petrol/fuel/gas.....(5000ml divided by 200ml= 25) most 2 stoke oil is able to run at 50: 1 mix ...instuctions on what oil ratio should be used are always displayed on the oil bottle you buy for aircooled 2 stroke engines....
Dec 03, 2013 | Garden
Air filter for Dynamac DY 41 chainsaw?
Nigel you could try Central Spares on the net
Nov 16, 2013 | Garden
Yiben Meiduc
your carb mixing screw may be to ritch so anny air resticition ist going to notmix fuel and air right lean it out
Sep 24, 2013 | RTO 50cc Moped Scooter
I cant find a replacement air filter locally, can i use the foam one instead?
Air filter's function is to protect dust going to the carburettor, so I think similar material will work ! (make sure do not effect the air flow)
Sep 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain saw was working fine and shut down suddenly. The gas/oil mixture was bubbling so I let cool. I also cleaned the air filter on the carbureator that was blocked. It still won"t start.
The fuel lines may have become air-locked.This can happen if the tank is run dry. If the saw has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.
If you're up to it, you can dismantle the carburettor and clean any dirt from valves.The carburettors on chainsaws, hedge cutters etc. are very fiddly with delicate diaphragms, valves and springs so you have to be careful to avoid damage or loosing parts.
Ensure air filter is clean. Foam elements can be washed with hot water and detergent, squeezed dry in a cloth and re-oiled with a teaspoon of engine oil spread through the foam. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
Check fuel lines aren't kinked or blocked restricting fuel flow.
Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
Check the throttle cable is actuating the throttle plate in the carburettor.
Check whether there is a vent on the tank or on fuel cap. There is usually a valve on this to allow air into tank to replace fuel as it leaves for the carburettor. Ensure this isn't blocked.
Jun 20, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I just rebuilt my zama carburetor on my husqvarna saw and it still doesnt run right and i have blowed out my fuel filter and checked all lines and even tried to adjist the carburetor and it still cranks...
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
You can also buy
an aerosol can of starter fluid at your local autoparts store. This is sprayed into the carburettor to clear any partial blockages.
Apr 14, 2011 | Husky Husqvarna Chain Saw 240E w 16in bar
I have a stihl 076av all of a sudden she will not start getting plenty spark been running as should
The fuel lines may have become airlocked.This can happen if the tank is run dry. If the saw has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.
If you're up to it, you can dismantle the carburettor and clean any dirt from valves.The carburettors on chainsaws, hedge cutters etc are very fiddly with delicate diaphragms, valves and springs so you have to be careful to avoid damage or loosing parts.
Hope this helps !
Apr 07, 2011 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
Mine was running fine , set it down to take a break. Restarted just fine, and idels great , but as soon as the throttle is applied it dies..help.....
Apr 06, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Homelite 16" 33cc chainsaw. Sarts but win't keep
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Homelite Garden
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
