AC-554SY05-7S - Computers & Internet
Ming an ac/ac adapter model mao-122300
Are you %100 sure it's not 12v DC on the ouput side?
Jun 06, 2012 | Computers & Internet
Can you take a 97 f150 with ac and bypass the ac pully with a belt for a no ac engine
i purchased the AC delete belt...do i have to remove anything to properly install? or do i just take off old bet and put on short belt and crank tensioner the correct way? it seems that the ac compressor pulley is in the way?
Mar 14, 2012 | Ford F-150 Cars & Trucks
How to replace ac compressor to a 2003 f 250 5.4
An Air-Conditioner loses its fizz with passage of time due to constant usage or wear and tear.Just dial to Dailfix they will help you with all things.
AC Repairs Services in Hyderabad Dialfix
Jul 15, 2011 | Ford F-250 Cars & Trucks
Non ac belt on engine with ac
yes. I would also remove the ac compressor all together, but it will be fine with the non ac belt
Jul 07, 2010 | 2004 Isuzu Rodeo
1997 pyzar 1.5 ac full of gas but ac wont work
CHECK AC COMPRESSOR CLUTCH SHOULD BE ENGAGED OR RUNNING WITH AC SWITCH ON POSITION.IF NOT CHECK AC COMPRESSOR CLUTCH FUSE AND RELAY.IF BOTH GOOD AND POWER IS GOING TO AC CLUTCH.YOUR CLUTCH IS OPEN.IF ALL LOOKS GOOD YOUR AC LOW PRESSURE SWITCH IS BAD.COMPRESSOR SEIZED OR YOU HAVE TOO MUCH MOISTURE IN AC SYSTEM.
Mar 10, 2010 | 1991 Daihatsu Charade
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
How do you check the high pressure on the air conditioner for a 1997 volvo 850
Do you have ac gauges?You can only check with set of 134a gauges.Hook the red hose of the ac gauges to the large ac port on the high side ac line(it is the small ac line/hose).Do not turn the red knob on (on the ac gauges)If need to hook up low side(blue hose)to the small ac port on the low side line(it is the large ac port).If I can help,let me know.
Sep 09, 2009 | 1995 Volvo 850
Ac knob on kia has a short?
blower motor is going bad replace and have your ac system checked by trained tech
Mar 15, 2009 | 2004 Kia Sedona
AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
DiMAGE E201 overseas?
Yes. When using an AC adapter, please use the one suitable for the voltage level of your destination country. North America, Taiwan: AC adapter AC-1L; Europe (except UK) and Singapore: AC adapter AC-2L; UK and Hong Kong: AC adapter AC-2L; Japan: AC adapter AC-1L. You may have to switch video output mode between PAL and NTSC to view images on the television.
Computers & Internet Logo
David Payne
David Payne
