Question about Generic Memory Compaq Presario SR1215CL by HP AMD Sempron 3000+ 512MB 120GB CDRW/DVD w/XP [Refurb] [MIN90] PJ506AA... (PJ506AAR) PC Desktop
Presario will not start
My presario SR1215CL will not start. I cannot get it to respond all all , nothing.Juat a small green light flashes underneath the connection in back for the power cord. apc surge protector is ok all else works fine when plugged into it. what can i do?
  • 231 Answers
Hi, remove the left side of your case, turn on power and see if you can see a red or green led light on the board, if its not showing then your power supply is faulty. If the light is on then with the power off check the RAM chips are tight. if that does'nt work Then trace the cables from the front of the case, locate which is the pwr switch and unplug that, turn the poweron and then use a small screw driver and bridge the pins of the pwr switch. If this does not work you have either a dead CPU or a dead motherboard. Regards mistyman
Posted on Oct 08, 2007
  • 2,022 Answers
Just remove the power cord and fix again and the conncetor of motherboard remove and switch on system and then remove ram and fix it again bye
Posted on Oct 09, 2007
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Moved my desktp computer PJ506AA and it now will not turn on. Light in back is flashing.
Try re inserting the cables connected to your CPU, if it doesn't work,
you need to open the CPU case and re-insert the IO cards inside, it might also needs cleaning inside but a technician might be needed to do the cleaning correctly, due to sensitive parts inside.
Try to watch videos on how to insert IO cards on other sites, for your guide. Good day and good luck.
Jun 06, 2012 | HP Compaq Presario SR1215CL (82916052980)...
Runing out for hardrive, can I just add more hard drive. 120gb and want to go to 3-500 gb. Can my model handle it? sr1215cl
According to the specifications, the motherboard supports two PATA hard drives and two SATA hard drives.
You can install SATA hard drives to any capacity you want.
Nov 07, 2010 | HP Compaq Presario SR1215CL (82916052980)...
Compaq Presario 5000 won't turn on
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
Tower will not turn on
I am in no way an expert on computers but after hours of research, of course starting at, and trying everything short of buying power supply and motherboard, i found a post that suggested to use a blow dryer and blow hot air over the area with the blinking light for about a minute. I was really reluctant to try this but am glad i did. In less than a minute i could hear the comp powering up and the light went and stayed solid, so far that is. I always use for everything and wanted to put what helped me on here in case it can help someone else or save them hours of research. I hope this help some. Good luck.
May 04, 2009 | Generic Memory Compaq Presario SR1215CL by...
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
MyCasio exilim 2.0 won't charge!
Juat wondering if you have a casio exilim ex-s2 that you would want to sell for parts? Or if you know anyone that has one? please let me know
Feb 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Computers & Internet Logo
425 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
