Question about Kenwood DPX500BT USB/CD Receiver with Built-in Bluetooth
Kenwood How To Install
Installing into a 2004 pontiac grand am with a monsoon sound system.
My JVC cd receiver model Kd R-310 reads protect on the display and won't work. I cut the wires to try to install it in my 2002 grand am. Can this be fixed?
Repair cost would exceed replacement cost. Try disconnecting all the speakers and see if it works then. Try reconnecting each speaker by itself and see if that causes the problem. Most grand am have the monsoon sound syatem...even if they aren't labeled as such. Pull the carpet in the trunk on the left (drivers) side wheel well. The monsoon amp is located over the wheel if you have a monsoon system. If you have to remove the amp then you must change the speakers out or rewire them as the monsoon system uses bi amp speakers. Most of the ga forums have extensive write ups on this system.
Oct 29, 2016 | JVC Car Audio & Video
I have a 2000 Oldsmobile alero and I can't get any sound out of my rear speakers good speakers and connection just can't get any sound out of them
Installing/Replacing rear speakers in a 2002 Pontiac Grand ...
? 5:11
https://www.youtube.com/watch?v=aiWwA6bXvhE
Nov 30, 2010 - Uploaded by Turbo231
Installing/Replacing rear speakers in a 2002 Pontiac Grand Prix GT DIY ... same as a 2000 grand prix ...
How to remove back speakers and install in a 98 02 ...
? 17:50
https://www.youtube.com/watch?v=pIxGeqy9QYI
Feb 26, 2014 - Uploaded by Can't Kill Me
How to remove back speakers and install in a 98 02 Oldsmobile Intrigue. Can't Kill Me ... 6x9 Rear Car ...
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
how do you replace rear speakers? - Aleromod.com
www.aleromod.com > ... > General Help > Audio, Video & Security
Feb 13, 2013 - 20 posts - ‎7 authors
I just tryed it and I have no idea how to take that plasic thing out! ... I replaced the deckspeakers on my alero as well as my friends and didn't .... remove the rear deck...next thing is that if you have monsoon sound let ... Get better aftermarket speakers and then say ehh...i wanna go back to the weak stockers. Stero Question
May 21, 2013
Monsoon and aftermarket speakers
Sep 9, 2011
Aftermarket Headunits, Wiring Harnesses
Feb 19, 2004
Installing Aftermarket Radio, 2001-2004
Nov 20, 2003
More results from www.aleromod.com
Jan 21, 2016 | Oldsmobile Cars & Trucks
Does a 2004 Pontiac Montana's radio have an amplifier? If it does, where would it be???
Unless the face of the stereo says MONSOON there is no separate amplifier. On a Non-Monsoon Delco system all four amplifiers are built into the stereo, Left front, Right front, Left rear, and Right rear. Monsoon systems do have a separate amplifier which basically boosts the output of the four regular amps in the radio. I can't imagine all four of those amplifier output chips going out at the exact same time. I would pull the stereo and check if all plugs are seated properly. If those were all securely plugged in I would (myself) inspect the inside of the unit for the cause of failure. For example all four amp chips pull power from a common point and if one chip had a severe enough short in it, this may have caused the power feed trace on a circuit board to overload (too much current going through it) and created an open which killed power to all four of them. Any good electronics repair shop worth their salt should be able to repair it if you can locate one willing to try. It may only need a circuit board trace repair and one amp chip replaced.
Mar 07, 2015 | 2004 Pontiac Montana
Converting Monsoon stereo to Alpine
Did you by any chance change your mids and highs amp??? Or just your radio???
Feb 24, 2013 | Alpine Car Audio & Video
How to splice factory speaker wires on 2004 grand am with monsoon
everything depence of system you putting in your car if u have no amplifire you connecting the speakers to radio as they marked i you putting one in, your speakers wires goes from amplifire to speakers there is no diffrent way of connection. also the diameter of your wires have to be adekwate to power u going to have in your system for optimizing the sound quality let me know if this help ya
Sep 22, 2012 | 2004 Pontiac Grand Am
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
Radio Wiring Diagram
Go to www.crutchfield.com.
On the bottom of the page there is a link for product support. On the next page, type "2005 Grand Prix" in the search box and hit enter. The top link shows an image and pinout on models with Monsoon sound systems, the second link for ones without.
Hope that helps! Good luck!
Jun 13, 2008 | 2005 Pontiac Grand Prix
Kenwood DPX500BT USB/CD Receiver with Built-in Bluetooth Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
