Question about Tools & Hardware - Others
Culligan aquada uv code al5
What is code al5
2 Suggested Answers
  • 884 Answers
SOURCE: Culligan Air Purfication System Blown Fuses
Check for an earth fault or short circuit. Most likely fan seized.
Posted on Apr 22, 2012
Culligan Mark 100 Had code C5 Doe not work. What does code C5 mean?
A lot of people mistake the "S" as a 5. The error dispaly says "CS" which means call service. You probably have a gasket hung up and need a new seal pack.
Mar 04, 2015 | Culligan Measuring Tools & Sensors
Culligan gold series alarm 1 error
Hope you got this fixed Oscar, Since you have a manual and everything you've tried hasn't worked consider it either broken or something has failed. Could be a filter element you can change or a sensor that has failed. I haven't found a manual to look at so don't know if this system has any parts you can check or change. Also could be a UV bulb if it has one or the timer that calculates the bulbs life. Sorry not much help.
Sep 01, 2012 | Culligan Sediment Water Filter Heavy Duty
Apr 10, 2012 | Air Purifiers
Culligan water system not working. Display code CS. Where do I start to look for issues
If the unit is running to drain the sealpack needs to be replaced. Try unplugging it for 2 minutes then plug back in, it may clear code.
RJ
Jul 17, 2011 | Culligan Sediment Water Filter Heavy Duty
Culligan mark 100 fixed problem I just need to know how to reset the CS code without calling them out.
Just unplug it for several minutes. You will need to reset the programming, hardness, time of day.
RJ
Feb 12, 2011 | Culligan Sediment Water Filter Heavy Duty
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Zanussi aqua pulse de 6965
We have AL5 quite requlary. It seems to be related to the pressure of the water going into the machine. I think if it is too high this alarm can be tripped.
There are two main ways we rectify the problem:
1. switch off the inlet water supply. Disconnect the hose at the machine. Let any surplus water drain out (only a couple of spoonfuls). Reconnect and switch on water.
That sometimes resets a sensor inside that relates to the AL5.
2. If the above fails then we remove the panel where the inlet water hose connects to the machine (There are three screws). Then carefully left this panel away from the machine. It will not come right out as it is connected to various bits inside the machine but you can get some access inside. On the left hand side there is a pink pipe with a white stopper on the end. Remove the stopper and let an excess of water out (this might be as much as a cup full). Of course, this must be done with the machine switched off and un-plugged from the mains!! There are electrics inside.
Once the pink pipe is drained, put the stopper back on and reassemble and connect. 90% of the time this works fine.... but the problem does come back.
If it doesn't work after the second procedure has been done then try leaving it over night (with the water inlet switched off) and try again in the morning.
I have experimented with putting the inlet tap half on (i.e. to lessen the flow of water) and that seems to give us longer before the problem returns.
I checked on a site a while back which had suggested that Zanussi were aware of a design problem. Of course, unless cars, they have no recall policy. I have tried to ring them once or twice but have got nowhere. Its hard to tell at times whether you are ringing the right company let alone the right department!!
Aug 24, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
