Question about Dell 2155cdn All-In-One Laser Printer
Dell 2155cdn says offline
My Dell 2155cdn will not print. Says it is offline - trouble shooting tells me the printer is not turned on. Have tried to turn printer off/on several times, but it will not reconnect. Any suggestions?
SOURCE: dell 1710
Not a solution - - but - - don't listen to the Dell idiots.
I've been through two 1710 and 1710n printers and it continues to happen.
No solution have I found.
Posted on Mar 23, 2008
  • 7 Answers
SOURCE: Dell 946 will not print after one print
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
Ajkill
  • 2035 Answers
SOURCE: error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 03, 2009
  • 73 Answers
SOURCE: Dell 1710 offline cannot print
Can you right click on the printer and select "use printer online"?
Posted on Feb 10, 2009
  • 50 Answers
SOURCE: status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Posted on Mar 24, 2009
Printer is not responding
printer offline means disconnected or turned off.
did you try to check if its selected as default to your computer?.
1, check device and printer of your computer and make your printer default,
2, use the usb cord of the printer first, so you could use your printer and configure it to wifi setup.
Apr 22, 2015 | Epson Expression Home XP-410 Small-in-One...
How to print black only, yellow is out?
Most printers will not allow you to print without all cartridges active. If you printer is capable of that you can go into the printer settings on the control panel and go into options or print menu. Under that you can select B/W printing only. Try that out.
Jul 15, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Dell 2155cdn toner rubs off
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
Feb 19, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
2155cn printer giving error #006-370 what should I do
Power off the printer and turn it on again with the big button held down (the one with the tick on it).
This seems to clear the error and allow printing but won't fix the fault itself.
Feb 17, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Dell 2155cn will not print
Hi Joyce,
Use this link for help:
Troubleshooting Printhead Problems on the Dell AIO V313 V313w V515w...
  1. Turn off the printer, and remove the Printhead out of the printer,
  2. Connect the printer and the computer with a USB cable and turn on the printer.
  3. Open this link in the computer:
Drivers Downloads Dell US
4.Select the operating system of the computer from the list of options.
5. Under the Firmware, select the right Firmware according to the printer model depending on Wifi mode.
6. Click "Get driver" and follow the onscreen instructions and update the Firmware software.
7. Reinsert the printhead and try printing and check.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Dell Printer Support
Feb 05, 2014 | Dell 2155cn and 2155cdn Color Laser...
Status on print job says offline dell m5200
a few questions:
solution:
or
Mar 24, 2009 | Dell M5200n Laser Printer
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Dell 2155cdn All-In-One Laser Printer Logo
260 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
