Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Replaceing Faucet Parts
Does the adjusting cap turn clockwise or counter clock to remove?
2 Suggested Answers
  • 349 Answers
SOURCE: brand new delta roman tub
Cna you remove water line feeding hot side to make sure it has correct flow. It could have something blocking inside of water line. And check hot inlet side on faucet to make sure it is open and not blocked.
Remove line you can run water in a bucket to ensure that hot side water line has no blockage in it and have someone help you with turning water off and on for you.
Posted on Aug 02, 2011
How do you remove the spout cap (RP34090) from a 2 handle delta 2402 kitchen faucet? The spout cap is stuck.
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
Jun 10, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Tip
Adjusting the temperature setting on a Delta single handle faucet 13/14 series.
Delta single handle Tub & Shower faucet temperature control adjustment.
Step 1 - Remove handle to gain access to rotational limit stop. Once handle is off there ia a plastic limit stop disc. Remember where it is to start with. Metal handles require a 1/8" allen wrench to remove handle. Plastic handles require removal of cap to access screw to remove with phillip's head screw driver.
Step-2- To adjust the temperature of the water coming out of the valve, pull the disc back to a position where it is possible to remove the Rotational Limit Stop and readjust the teeth to desired position to acheive temperature. Once moved reinsert it into place to test water
Step-3- Clock wise will decrease the temperature and counter clockwise will increase the outlet temperature to a hotter setting. Temperature setting per tooth (notch) could result in 4 to 16 degree's based on inlet water conditions.
Check water temperatures to make sure it is at a safe temperature to avoid scalding. Safe operating temperatures range around 120 degree's. Some may have to be adjusted based on season's.
Winter season's when it is cold outside you may have to turn temperature up due to water coming into house will be colder than it would be in the summer.
on Jun 23, 2010 | Plumbing
How do you get the spout off?
Information on your faucet can be found here:
http://www.moen.com/chateau/chrome-two-handle-low-arc-kitchen-faucet/_/R-CONSUMER%3A7907
The exploded parts view can be helpful is seeing how your faucet is assembled:
http://www.moen.com/shared/pdf/7906pt.pdf
First turn off the hot and cold water supply taps. Then to remove the spout you simply unscrew the spout cap counter-clockwise; you should then be able to lift the spout up and off the supply post.
May 19, 2011 | Moen 7907 Chateau Two-Handle Kitchen...
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
i am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
Dec 29, 2010 | Delta Model 470: Signature Kitchen...
CANT FIND HOW TO REMOVE THE HANDLE TO ADJUST OR REMOVE THE SCALD GUARD
1-For a metal lever handle it will have a allen head screw at the base of the lever to remove with a 1/8" allen wrench. If you can not see screw it may have a cap covering it to remove.
2-To remove plastic acrylic caps remove plastic cap to acess screw to remove handle.
Once handle is off remember the location of the dial to adjust it counter clockwise to increase hot water flow. Slide indicator dial back on stem and reposition about a 1/4" turn counter clockwise and recheck for change in temperature.
If you need any more help refer to the link provided for a digram of faucet. Go to parts down load and view faucet parts view. I hope this will be helpful in solving your issue.
http://www.deltafaucet.com/bath/details/T13022.html
Dec 28, 2010 | Delta & Single Handle Shower Faucet
HOW DO YOU ADJUST THE SCAULD LEVEL
Remove the handle and bezel (face plate). Locate adjusting screw and turn right (counter-clockwise) to increase temp. or left (clockwise) to decrease. Check for desired temp before replacing face plate.
Jul 19, 2010 | Delta & Single Handle Shower Faucet
Slow drip from Delta single lever shower faucet
remove handle with allen wrench then unscrew sliver ring that covers ball with stem sticking out you might need a strap wrench if the threads are corroded
Mar 07, 2010 | Home
On adjusting headlight on 08 tundra does clockwise
clock wise should pull light up. counter clock wise should tilt down
Mar 07, 2010 | 2008 Toyota Tundra
Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Dec 30, 2008 | Home
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
32 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
