Home | Kodak | EasyShare Z1275 Digital Camera | My Z1275 kodak cam...
Kodak EasyShare Z1275 Digital Camera
Problem for Kodak EasyShare Z1275 Digital Camera
My Z1275 kodak camera's lens wont retrack. turn it
By hannahhinson on May 04, 2009
my Z1275 kodak camera's lens wont retrack. turn it on and then it goes right off.
Solution #1
posted on Aug 15, 2009
Not Rated)
BillB-SA
Rank: Guru  Kodak Cameras & Camcorders  Expert
Rating: 85%, 302 votes
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Comments:
Aug 16, 2009
- This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare Z1275 Digital
Questions and Unsolved Problems for Kodak EasyShare Z1275 Digital
Do you recommend Kodak EasyShare Z1275 Digital Camera?
Answer
Answer
My kodak easy share z1275 wont power on. I have bought new batteries but it still wont power on
Answer
can i put a sdhc card in the kodak easyshare z1275
Answer
when you turn it on it buzzes, flashes red, and shuts off. i have charged th battery completely
Answer
Z1275 produces horizontal lines through images. Flash, auto, program....doesn't matter what mode.
Answer
i cannot play any games that i download onto my pc, when i try to play them i get only half the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak EasyShare Z1275 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
