Question about Bosch Dishwashers
Watertap message Bosch dishwasher is displaying "watertap" - not sure what this means and there is nothing in the manual. The dishwasher will not run and is beeping with this message on.
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
ginko
  • 19396 Answers
SOURCE: Bosch Exxcel dishwasher. Message E09 what does
Hi.
E:09 is a fault detected in the heating circuit. Try first tripping circuit breaker (or disconnecting power cord) for five minutes and see if this can clear the error.
If that does not work, call Bosch at the number listed on the dishwasher manual. The repair is not suitable for the home user.
About E:09 I quote the good clarificatory explanation given by trikidik on this website.
"E:09 relates to a fault in the heating circuit. This new range of bosch machines do not heat the water in the same way as the older range. There is no water pressure switch on the heater assembly as the circ pump contains the heater in one complete unit (heat-pump). The control module monitors the speed & current draw of the circ pump to ensure that there is water in the sump & it is also circulating. Your machine must be less than 2 years old, so should still be under warranty. Its not a DIY fix, it needs an engineer to sort it, as it is probably a fault with either the heat-pump or the control module."
Regards.
Ginko.
Posted on Dec 26, 2010
Bosch dishwasher say "Watertap" error message. What do I need to do to fix it.
possibly turn the tap on or ensure that water is flowing through the tap
Jul 14, 2016 | Bosch Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
Bosch SilencePlus shows E:15, Aquastop, and Watertap!
Hi Greg,
E15 on the Bosch units indicated the base switch is activated. There is a safety switch which will activate the drain pump to avoid the base overflowing. Basically you either have a leak or possibly rodents living in the base of your dishwasher.
Easy way to check is first make sure no water is inside the washing area or sump (where the filter is). You will have a dribble there which the drain pump won't pump out but make sure it is mostly empty. The dishwasher always drains at the beginning of a cycle if you need to manually activate this, just turn you tap off so it doesn't try to fill. unplug your dishwasher then pull the machine out and place some old towels along the base and tip if forward. If water run out from the base then you got a leak.
If you are a bit handy then you can take either the front kick plate and cover off or a side panel to look in the base. The float switch is a polystyrene disc which raises and hits a micro switch when the base fills up.
Common place for these to leak is the sump, wash motor or water path / distribution unit. Look for chalky white residue around the seals. Depending on the age of your unit some parts are more serviceable than others. Bosch are pretty good with spare parts so you should be able to source most items you need.
If you are not handy or technical and are concerned about taking on this work, call in a technician. Remember disconnect power before attempting any work. please.
I hope this helps.
Apr 13, 2014 | Bosch Dishwashers
She68t52uc flashing light which says E:15 and watertap
Not sure if this will definitely work, but i do believe this is a flood safety device. Try removing the drain pipe from the waste pipe, into a bucket or bowl, and empty as much water out as you can, then, with the pipe on the floor (will get wet), tip the top of the dishwasher backwards about 45 degrees, and hold for a few seconds. It may be that water/suds are still in the bottom of the machine, or the dishwasher detected this.
Dec 26, 2013 | Bosch Dishwashers
Watertap message on Bosch dishwasher
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
Nov 16, 2013 | Bosch Dishwashers
Dishwasher will not run, gives a message "E-24"
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Feb 12, 2012 | Bosch Dishwashers
Dd603h my bottom drawer will not take in water - the top works fine. when i change motor the top still works fine and the botom still has a problem. it displays a watertap with a line over it sincerely...
The watertap with a line means the inlet water solenoid is faulty.
YOu will have to replace it with this part.
Please rate this solution if it was helpful otherwise post a comment and I will try to help futher.
Aug 11, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Bosch dishwasher lfestyle automatic runs for 1 min then displays e24?
Mar 31, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
80 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
