Question about Konica Minolta Office Equipment & Supplies
Konica 7165 error sc 80-02 - Konica Minolta Office Equipment & Supplies
3 Suggested Answers
firecontrol7
  • 6680 Answers
SOURCE: Error SC 29-03
Max Density error. Clean the senor looking at the drum?
Posted on May 09, 2009
  • 158 Answers
SOURCE: What is the code to manually clean the corona wire Konica 7165
47 mode output 046 p00p for charge 47 mode output 047 p00p for transfer
Posted on Oct 03, 2009
Fix the Error Code Sc 34-02
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Dec 16, 2015 | Konica Minolta 7155/7165/7255/7272/FORCE...
CODE 02-01 SC23-04
PCL connection area. Mite want to check all connections to the print control board. And Memory sticks, also have the firmware re-flashed.
Feb 08, 2013 | Konica Minolta TN601K Toner for 7155,...
Error code sc 21-3
Charge Corona Cleaning device is stuck or is jammed. This cleaning device clean a very thin gold plate wire above the drum which places a High Voltage charge on the drum. You will need to remove the drum cartridge to get to it. The wire cleaning is normally done upon turning the machine on it may sound like a high pitch squeal. It can also be turned off, and not used at all. Has to be done in service mode soft switch setting.
Dec 23, 2012 | Konica Minolta Dv601k 7165 Developer
How to reset error sc 23- 1
Sir/Mam,
Mite want to remove the toner bottle, shut the machine off first then remove the bottle then turn it on with no bottle then replace the bottle when the machine is asking for it.
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Error code sc 49-04 for konica 1050 copier
Aug 27, 2012 | Office Equipment & Supplies
SCANNING PROBLEM KNOICA 7165
contact whit the engineer probably u have to instal new firmware
Jun 23, 2009 | Konica Minolta Office Equipment & Supplies
Error SC 29-03
May 05, 2009 | OCE 3140 Copier
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
