Question about Behringer Europower Pmp1000 Powered Mixer Pmp Offer
Pop noise is heard when playing and the output stops playing
Loss power and makes noise when playing
Well this is a common issue with this mackie design, the 90% of this report comes out of a cracked output Mosfet's pins or Coil at output section, let me know further to help more.
Oct 31, 2013 | Mackie HD1801 Powered Subwoofer (1600...
12" woofer not working
I bought a 3rd B212D unit that powers on, has white noise, no music. I took the 8 screws off and discovered that the solder connection at the woofer had broken off. I surmise that either the unit was dropped or the speaker wire had gotten hot over the years. Since the amp had an open output from the break, the high output burned up as I heard a pop when I turned the volume up. . If your volume wasn't maxed out, you could check the wiring and make sure it is connected & save yourself some change!!!
Jun 22, 2012 | Behringer B212D Powered Speaker (550...
Hi my names jason and i have a crackling problem with one of my krk rokit 5 g2 played a few tune's and the one speaker won't stop poping please could you help me with this i don't...
Try swapping the monitors inputs. if the other speaker starts popping on the same output it'll show that the mixer may have a problem. otherwise return for repair.below is a link to the manual. check out the troubleshooting section pg 13
http://www.krksys.com/manuals/rokit/rpg2_manual.pdf
Sep 12, 2011 | KRK Rp5 Rokit 5 G2 Studio Monitors Rp5g2...
While the Mackie Onyx 1220i unit is plugged into my computer I can port the sound through to my headphones via the headphone jack on the console. When I listen to sound play for about 2 minutes I'll...
OK... first thing is to DUMP ALL anti-virus and Anti_spyware and real time defragging programs as these resource hogs **** processing away from teh sound generation. Also is you are recording at the same time, if your disk is fragmented requiring a lot of head movement to record the time lags can cause buffer underruns and break up of audio... and eventually having the audio program "crashing" due to lack of throughput.
When doing audio work suspend all the resource hogs like the above mentioned programs. It is a good idea when recording CD's as well.
Feb 10, 2011 | Mackie Onyx 1220i Onyx1220i Onyx-1220-i...
Goodmorning, I'll try to explain the problem: when I listen to the files (MIDI and MP3) directly with Cakewalk sd-50 using the USB Key the playback is correct. When I listen to the files playing them...
You have to make sure that the clockspeed of the program that you use to play the files back with matches the clockspeed of the program that created them. I might be wrong about that. Here is a good resource:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will have to join to access but its free and the Killer Home Recording setting up is also free from the site and is full of good info.
Dec 13, 2010 | Cakewalk Roland SD-50 Mobile Sound Canvas
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
FENDER HOT ROD DEVILLE 410 POPPING SOUND
I have answered some of this before, however I have reveiwed the schematic and as an electrical engineer I want you to do a couple tests.
First, plug in a set of headphones into the preamp out jack. Note that due to the impedance mismatch what you hear will not be very loud. Now change the state of the clean OD. Did you hear a faint pop?
Next plug a LOW impedance device OR even an instrument cable into the power amp "input" jack. Do this with the power off then warm amp up.
Now, change the state of the clean OD. Did you hear a faint pop?
Now for the analysis. If you did hear one in the first test and NOT in the second, the pop you are hearing is the "NATURE OF THE BEAST".
I can tell you from the design that the pop you hear is from coupling within the clean and OD relays within the unit. There is no cure for this within the unit other than find another brand...
I would recommend that you use an EXTERNAL pedal for the effects you want rather than trying to use the clean OD in this amp. I suspect it was never intended to be shifted during playing as I can guarantee it will pop when you shift while having anything other than dead silence (not even a bit of hum from your guitar). There is also statistical noise in the preamp that the laws of physics will not let us get around that may be enough to create a bit of a pop.
You could also use a volume pedal between the preamp output and the power amp in to throttle the volume to zero before shifting to OD.
In general I think you will find that what you are hearing is the nature of this beast.
Mar 18, 2010 | Peavey Music
Yamaha pt300. was working fine. Now only makes loud humming noise which doesn't repsond to change in volume. Monitor display shows keys register as being played, but no sound can be heard except loud...
Likely the power adapter has failed if it uses one. Try a new one first.
If half the rectifier blows out, a very impure DC voltage is applied which will be heard in the audio output.
Sep 27, 2009 | Dean Dimeblade Tribute Electric Guitar
Behringer Europower Pmp1000 Powered Mixer Pmp Offer Logo
22 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
