Question about Home Meridian Comfort Lift Recliner
I need to take the back off of my lift chair,
    Sergeant:
  • 264 Answers
On each side where the bracket slides into the mount there is a spring loaded pin that you have to push in then the back will slide off. You must push the pins on both sides at the same time . If you need parts Home Meridian...........
Posted on Nov 05, 2014
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
How do I lower the back?
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Nov 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How do I lower the back of my chair
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
Hi i have a pride jazzy jet 3 and i need to lift my chair using a hoist to put in the back of my car but can't find any bracket on the chair to lift it can help me please.
Contact the manufacturer of the lift for the brackets. Depending on what type of lift it is, you will either order the bracket from them or from a Pride Mobility Dealer or the lift dealer
Apr 05, 2014 | Pride Mobility Products New Pride Mobility...
Pronto m41 moves slow at all times
If you have a seat lift on your chair, you will have to lower the seat lift. This is call limp mode so the chair does not move to fast and tip over while the person is in the chair. If this is not the case, then your chair controller may be over heating and it will also cause the chair to go into limp mode. this is a better option than totally stopping. the way to correct this is to let the chair sit and "cool down" for a little while. It usually takes about 30 minutes, sometimes less in cooler environments to get the chair back to normal use. If neither are the solution, then you have a problem with the chair that causes the controller to reduce the output. You will need to get an authorized Tech to check the chair out to determine the root cause.
Oct 30, 2013 | Invacare Pronto M41 Power Wheelchair
How to remove the seat of a prono wheelchair
Hi. To lift of the seat, you need to pull the knob under the side of the seat that allows you to turn the seat. While you are pulling upward on this lever, use your other hand to lift the seat of its mount. This might be hard to do if the seat pivot is lacking any lube or a light film of oil.
You might have to disconnect the cable to the joystick control first.
Good luck. Neil.
Aug 23, 2011 | Invacare Pronto M51 Power Wheelchair
How do I remove the chair from my Pride Mobility Jet 3 power wheel chair? The manual just have one line of description! Do I need to remove the chair before getting by hands on the battery? My Jet 3 is of...
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Jun 30, 2009 | Jet 3 Ultra Power Chair
Home Meridian Comfort Lift Recliner Logo
122 people viewed this question
Top Home Meridian Furniture Experts
Peter
Peter
Tom Chichester
MobilityRepairSpecia...
Level 1 Expert
Are you a Home Meridian Furniture Expert? Answer questions, earn points and help others
