Question about Sony KDL46EX700 46 in LCD TV
Kdl46x700 the red light flash twice and the tv does not turn on
3 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: Tv will not turn on. Standby Light flashes twice.
UNPLUG AND TAKE OFF THE BACK AND CHECK THE FUSES,,MGT BE BLOWN,,
Posted on May 15, 2009
bbl242003
  • 1637 Answers
SOURCE: My tv was working fine last night, but now it
Please let me know if you can get any sound at all out of your unit.
solution
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Posted on Jan 12, 2011
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Sky remote code fo LCD LE40A456 TV
3. Press tv again
Samsung Code: 0060
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
3. Press tv again
Sony Code: 0000
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Pair sky+ remote to tv
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Temp ted light blinks twice then turns off tv
Your lamp might be bad. Also, it is possible that the lamp door is not closed.
Nov 21, 2007 | Zenith R57W46 57" Rear Projection...
Sony KDL46EX700 46 in LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
