Question about Behringer Europower Pmp1000 Powered Mixer Pmp Offer
There is a pop noise when playing```````````` and the output shut down.europower pmp1000
When playing a pop noise is heard then no output
2 Suggested Answers
  • 5603 Answers
SOURCE: behringer europower pmp1000, mixer unit,
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Posted on Jun 26, 2011
Volume is low when i use cd input
What kind of CD unit are you using? Is it a portable, rack-mount, stand-alone, or via computer output? This information is necessary. I will be glad to help otherwise.
Jan 10, 2013 | Behringer Europower Pmp1000 Powered Mixer...
I'm a retired electronic tech. and like to know all the in's andout's of this latest purcheses. Like the input ports 13 to 16 on PMP1000, what are there spec's? So I would appreciate a...
The PMH1000 is VERY close to the PMP1000 and circuitry is almost identical:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "Get Manual" and click on it to download... IGNORE other downlooad links. Also please read my tip about a hazard for PMP mixers regarding using SPeakon to 1/4 inch plugs for speakers. The tip of channel B is the hot... BUT the sleeve of channel A is hot and grounding it can blow channel A amp. This has class "D" switching power amps which are efficient. The power supply is a switching type that runs off the line voltage. Working on the supply requies using an isolation transformer for personal safety.
Sep 14, 2011 | Behringer PMP1000 Europower Powered Mixer
My mixer stopped working out of the blue no power want turn on anything ??????????????
Power supply probably failed. This is not a DIY for the inexperienced.
This will be close to your schematic: http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Final amplifier shuttoff after a few seconds
Guessing this happens each time you switch on so it's not a power problem.
Amps have built in mechanisms to shut themselves off to protect from overheating. First thing to do is check the vents are clean and the fan is working properly.
Jun 23, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No sound from the left side
Assuming your PAN controls are all at 12 o'clock, it looks like you have popped one side of the power amp. Please read my tip on here about the HAZARD on the "A" channel of PMP powered mixers. Essentailly, if you use Speakon to 1/4 inch cables or adapters the BARREL or the SLEEVE of channel "A" connector is the HOT side of the speaker and touch ground with it and goodbye Channel A side amp. They don't tell you about this in the manual. The tip of the plug is e cold side of the amp output UNLIKE channel B where the tip is the hot side. They do this to make it easy to implement "bridged mode".
Reepair of thes amps takes skill. This likely has the DPA300 module in it and you will find one side fried switching transistors and often a Zener diode. Sometimes the circuit board will have arced and be damaged.
Feb 28, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
Feb 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer Europower Pmp1000 Powered Mixer Pmp Offer Logo
37 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
