Question about VeriFone Vx 510le Credit Card Terminal
Verifone 510 error 3 write comm fail
When attemping a download, the machine give the following error- error 3 write comm fail
5 Suggested Answers
SOURCE: COMM ERROR on Verifone 3750
This could be a number of things.
#1 do you have DSL internet service? If so do you have a DSL filter between the jack and your terminal?
#2 Do you have digital phone service? Vontage or Comcast will cause this problem . Especially upon batching out the terminal.
#3 Check the blind dial setting within the other setup option. This option is buried, so it will require a phone call to Merchant service Provider.
If none of these work, then it is time for a new service. Place a call the Heartland Payment Systems Credit Card Processing and change your card service provider. The only card service provider that has a merchant bill of rights and field service techs (for free).
Posted on Nov 28, 2008
  • 12 Answers
SOURCE: VeriFone Omni 3750
Try connecting a laptop to that cable and see if that laptop can get to the internet. If not, then the connection is bad and needs repair. If the laptop can get to the internet on that cable, then the unit has gone bad and needs the communications module replaced. - Call your processor to get a new unit.
Posted on Dec 19, 2008
  • 9 Answers
SOURCE: I recently switched locations and
The most common error with these terminals is that they are connected improperly. Everyone plugs the power in first then the rest of the cables. Ensure that your cables are plugged into the proper ports first. The 10-Base-T port is for internet only, the Phone icon port is for phone line, the RS232 is not used unless otherwise stated, the Calculator looking port is for pin pads only. Once the cables are properly connected reboot the terminal by unplugging the power cable for roughly 10-15 seconds then plugging the power back in. Once it starts again it should be fine. If you are running on a multiline system for phone the terminal will not dial out unless you set the prefix to dial 9 first.
Posted on Sep 06, 2011
  • 113 Answers
SOURCE: verifone omni 3750, Error: invalid
this will happen if you do have a single com module and the program is set up for 10base ( internet ) com if this is the case you will need a dual com module the first thing the unit does when you run a transaction is to look for the com port is it is 10 base it will look for the internet connection " BUT " if the comm module is bad meaning it took a power surge hit them you have to replace it if you need more help call us @ 775- 358 2922 hope this help : - )
Posted on Dec 12, 2011
How do I change the auto settlement time on verifone vx 510
Press 6 then set up, enter password- alpha alpha 66831 enter (alpha key above 2 key) then it will display
phone
terminal
communications
Select Terminal using purple more key or the next key if one displays until you see auto settle time. Press Select- then on bottom of screen you can enter the time using HHMM- military time. if you want to close at 1100pm you would enter 2300 press exit and yes to save, red x until back at main screen. if your screen goes to a default screen that says comm serv and something else, choose the option that is not comm serv and this should take you to a home screen you are used to seeing.
Feb 27, 2015 | VeriFone VX510
Verifone error codes
your internet connection has stopped, check your internet if you can unplug the power and then the Ethernet cord, then plug back in and wait 1 minute before you power on. you can also press the * key and then comm server, then the icon that looks like tools, then ping test, enter in a yahoo.com using the numbers on the keys then press enter to do a ping test, press yes you want a continuous test,if it fails reset your modem or router and try again. if this does not work you should check with isp to make sure internet is working
Aug 20, 2014 | VeriFone Omni VX-510 Credit Card Machine...
VeriFone VX510 TCP error 1009
your internet connection is not established check internet and Ethernet cables. may have to reboot your modem
Jan 27, 2014 | VeriFone Omni VX-510 Credit Card Machine...
Verifone 3730 vx 510
Hello all, I have a pos Verifone Vx510I configured the IP, DNS and Gateway, I did a ping, and it worked.
I selected Troubleshooting and verify all OK responses are received.
When I try use the machine show me the message "Connection Failed".
When I try download TCP show me the message :Connection to Host Failed
*ZP=08447016306:0Comms Failure -56Help me please !!Thank youCoil McCoy
Jun 24, 2012 | VeriFone Omni 3700
Verifone vx570 checksum error
Maybe you have a corrupted program/application. Call your credit processor for the download process of your application. But before downloading, don't forget to batch and settle your unit if you can. Then clear all the old program in your machine. I hope this will help you. if need more help call (775)358-2922 ask for Randy. Thanks
Jan 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
My power went out and i have a message saying security alarm, bad rtc chip , please reboot...how do i reboot..i have the verifone onmi 5100 vx 510
your power comm board is fry that's why it will not work the only way is to replace the board you have what we call power surge to the board
Jul 14, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
How do I change the ink cartrage on a verifone 460 tranz
Here is a link where you can view/download the manual:
http://www.1nbcard.com/content/images/product_docs/Verifone_TRANZ460_User_Manual.pdf
I believe page 3-2 will show you how to install the ink cassette.
I hope this helps.
best of luck!!
Mar 02, 2011 | VeriFone M25100033NAB Vx 510 Countertop...
VeriFone Vx670 can't download shows error open comm fail. Modem open failed. How can i fix this? Thank you
they have a 3 step process in setting up the hand held device I have included a link to the page http://www.dcrs.com/pics/db/document_library/000158.pdf one major priority is to have a secure wireless connection on site, not a shared one
Mel
Jul 16, 2010 | Computers & Internet
VeriFone Vx 510le Credit Card Terminal Logo
59 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
