Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Haier HR-135AR/A fridge not cooling
Have power and compressor heating up when left on. Have adjusted thermostat
Haier fridge not cooling
You need a service engineer. It is either low on refrigerant gas, the thermostat is faulty, or the compressor has failed.
Dec 20, 2016 | Haier Refrigerators
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Freezer works , refrigerator does not cool
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 23, 2011 | Haier RRTG21PAB (207 cu ft) Top Freezer...
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
The refrigerator is not cooling.
Must have to think of checking fromt eh begining
check the compressor, the pumping and speed, the gas pressure if sufficient. Switch off the fridge and start after about 8 hours, if the fault of cooling is present then the compressor / gas must be checked. if it cools and then drops off you must check on thermostat, autodefrost.
Sep 23, 2010 | Haier Refrigerators
Refrigerator makes a click sound now and again like its supposed to cool things down but not cold air. Still power going to it and the thermostat still has power. Unit is a Haiet BC-111.
TJ,
The starter on your compressor decided to go on strike. Fire it and get a new one. There's a universal starter I use all the time... it's a "PRO41". You can get one online or at a local appliance parts retailer.
Super easy to install. Pull the unit out and UNPLUG IT. Now remove the panel that's covering the compressor. On the left side of the compressor, you'll see the starter assy. (it may be under a plastic cover---> remove that).
Now just pry the old starter off and hook up the new one. Just line the pins up and press it on! That's it... fridge fixed.
Rate this solution, will ya? Show me some Expert (freebie) love.
SG
Apr 19, 2009 | Haier BC112G Wine Cooler
Have a Haier water cooler with the fridge compartment in the bottom. Compressor on the unit just started running continuously, instead of cycling on and off. now the chilling bowl that cools the water...
removed one of the two thermostats... the one that controls the temp in the lower refrigerated compartment. Now the water cooler functions correctly but the lower refrigerator is not cold enough to keep perishable food in it, but its better than it was.
Dec 09, 2008 | Haier Refrigerators
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
19 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
