Question about Friedrich D50C Dehumidifier
Bought Friedrich Dehumidifier one month ago, worked well, but now turns on for a few seconds and then stops. This on & off process continues. Bucket is empty.
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Friedrich dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
rctseohub
  • 10 Answers
Dehumidifier works great. Replaced an old unit with this one. Has removed a ton of moisture from the air. Maintains a comfortable temperature in our basement too. Easy setup.
Posted on Jul 04, 2015
Hi. My dehumidifier stopped working. It powers on, but does not do anything.
Check if the full light is lit. If so check that the float switch is free.
On page 5 step 3 they discribe how the float switch needs to be free?
http://www.sylvane.com/media/documents/products/friedrich-d70bp-dehumidifier-owners-manual.pdf
Jan 16, 2016 | Friedrich Dehumidifiers D70bp
3 or 4 years old. the entire unit shuts of every 2 or three minutes. it stays off for a few seconds, then restarts
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
-0-0
Sep 11, 2011 | Friedrich D50C Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
My D50C friedrich dehumidifier does not work. It runs - but will not extract the humidity from the air. It has only been used approx. 2 summers - no more - because last summer could not even run it. It...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 20, 2011 | Friedrich D50C Dehumidifier
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
Sep 01, 2017 | Kenmore 54501 Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Friedrich D50C Dehumidifier Logo
56 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
bobalix
FixIt_Right
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
