Honeywell helpline My CT3400 low bat indicator came on, all other functions are off. I replaced the batteries with AA Alkalyine and that worked for a few min. then when off. I would like to try a new thermostat unit but can not find a CT3400. Can you help?
ACTECH
  • 80 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Posted on Dec 19, 2007
SOURCE: I have a Honeywell T8131C
I tried all the tricks mentioned previously to no avail.
These are the steps I performed to get it to work:
1. Remove batteries and make sure the battery contacts inside the unit are clean.
2. Disconnect all the wires from the back of the unit. Be careful not let any of the bare wire ends to come in contact with each other. Make sure you mark the wires or verify that the color code matches the markings on the rear cover:
W=White wire;
Y=Yellow wire;
G=Green wire;
R=Red wire (low voltage DC); and
C=Common (wire color varies)
3. Leave the unit disconnected with batteries removed for about an hour to make sure all the memory drains. I waited an hour, but it may not require that much time.
4. Install the batteries in the correct positions per the instructions. The unit should perform a power up display test, then the display will flash the time and temperature.
5. Set the clock and the display will stop flashing.
6. Slide the switch to cool and/or heat and program the desired weekday/weekend settings.
7. Slide the switch back to off once all weekday/weekend settings are made.
8. Reconnect the wires that were removed in step 2.
9. System should be operational at this time.
Posted on Apr 22, 2009
  • 340 Answers
SOURCE: wiring in a new thermostat
yes .common as in the netural side of the transformer x to cif not hooked up the stat will still work. and honeywell has good support for their products . Tom
Posted on Jun 21, 2009
SOURCE: Screen says bat low
Found the manual online and it said to put the batteries in backwards for at least 5 seconds to re-set the thermostat. Amazingly, this worked.
Posted on Oct 02, 2009
Testimonial: "cool"
  • 587 Answers
SOURCE: We just replaced the batteries in our Honeywell
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 07, 2010
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
We have a Honeywell T8132A1049 thermostat/ cooler- we can't find a manual for it. It also says Bat Low on the screen but I have replaced the batteries with brand new ones and tried resetting it .....
Here is a link where you can download the user manual. It says to remove the batteries, wait 1 hr, then install fresh batteries. When the page for diplodocs opens click on security number and enter the code it shows to download the manual.
http://safemanuals.com/314159.php?k=af5d595162dd03d6ac627239ba1fbecf&ID=530143&q=HONEYWELL%20T8132A
Jun 08, 2010 | Honeywell Heating & Cooling
We just replaced the batteries in our Honeywell CT3400 thermostat, and for a moment or two, the display came on, but the thermostat was not responsive to the touchpad. Now, the there is no display, and we...
HONEYWELL WEBSITE:
Go to honeywell.com
Jun 05, 2010 | Heating & Cooling
How do I open the Honeywell programmable thermostat Model CT3400? I've never done it before and don't know how to open it.
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
Screen says bat low
Oct 01, 2009 | Honeywell Programmable Thermostat Heater
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
Open Questions:
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
