Question about Conair Weight Watchers WW-87 Body Fat Glass Scale
Battery for conair scale v24130 - Conair Weight Watchers WW-87 Body Fat Glass Scale
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
SOURCE: I have a Conair Weight watchers digital scale, how
replace it with 9v lithium battery that you can get anywhere.
http://www.google.com/products?q=+9v+lithium+battery&hl=en&aq=f
Posted on Nov 06, 2009
SOURCE: replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 29, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
Just replaced battery in my Conair WW87 scale and the numbers now do not display fully. Broken up
Recheck the battery connections and check the batteries, this type of display most times means low battery voltage.
Sep 12, 2016 | Conair Weight Watchers WW-87 Body Fat...
Battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Sep 25, 2008 | Health & Beauty
Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
423 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
