Question about Seagate Central STCG3000100 3 TB External Network Hard Drive - Black
My Seagate Central will not power up. I removed the drive and installed it in an external USB case, but Windows will not read the file structure. Is there a software or hardware solution to recover the data stored on the drive
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
lserni
  • 466 Answers
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Posted on Nov 25, 2009
lock123
  • 6831 Answers
SOURCE: Seagate Free Agent Desktop 500 GB USB External Hard Drive
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
lock123
  • 6831 Answers
SOURCE: Dead Seagate external hard drive
Hello
Kind Regards
Andrea
Posted on Sep 29, 2010
Format seagate central drive
Lots of info here
  • Seagate Central ' Seagate www.seagate.com/.../network-storage/seagate-central Seagate Central Drive - Quick Start Guide, Installation, Troubleshooting Tips & Downloads.
  • Reformat Seagate Central NAS - NAS / RAID - Storage www.tomshardware.com > Forum > Storage HI - anyone know if it is possible to reformat the Seagate Central Home NAS boxes with NTFS. Also anyone know ifit is possible to use Active Directory user accounts?
  • Seagate Technology - Official Site www.seagate.com Seagate is the company the world trusts to store our lives - our files and photos, our libraries and histories, our science and progress.
  • How to format your hard drive - Search ' Seagate knowledge.seagate.com/articles/en_US/faq/220151en How to format your hard drive Seagate external drives come preformatted, some for PCs, some for Macs, and some of them have special utilities allowing them to work ...
  • VIDEOS TOO
  • Go to Bing homepage
    Aug 03, 2016 | Seagate Technology Seagate Central 2TB
    Need to install the hard drive from the Seagate Central into a computer to recover data.
    Easier way if computer has USB ports, just use a USB convertor for IDE and Sata, (search for usb hard drive convertor) ( $10 or So) and you will be able to copy your files to the computer and to save to another hard drive or CD or DVD.
    Apr 17, 2014 | Seagate Technology Seagate Central 4TB
    Installation
    I got this from Seagate:
    "Set-up is straightforward, simply connect a single USB cable and you are ready to go. The drive is powered
    from the USB cable, so there is no need for an external power supply. Plus, it is automatically recognized by
    Windows
    operating system, so there is no software to install and nothing to configure. Saving files is easy too,
    just drag-and-drop.
    Highlights
    • Plug n' play - no software to install
    • Simply drag-and-drop to save files
    • USB powered
    • Built-in power management ensures energy-efficient operation"
    According to them there is no manual ans installation should be automatic.
    Jun 16, 2012 | Seagate Expansion 1.5 TB USB 2.0 Portable...
    Seagate freeagent goflex 3tb goes to sleep
    It is probably not a problem with the Seagate. It is more likely the computer has turned off the USB port to save energy. This article is from HP but it should apply to your situation, follow the instructions. HP and Compaq PCs USB Devices Quit Working Unexpectedly Windows XP HP...
    May 13, 2017 | Seagate Freeagent Goflex Desk 3 TB Desktop...
    Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
    it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
    Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
    I plugged in the wrong power cord to my p/n 9nk2ag-500. Is there a way to fix? or self extract files? I keep hearing about a SATA gadget that can convert any externat HD to a USB powered, will this bypass...
    yes if the hard drive is not damage
    you can use a external sata case to read your hard drive.
    remove the casing off the seagate freeagent to get to the hard drive.
    you need to get a 3.5" external sata case.
    you can get one from newegg.com or at your local fry's
    this is what i have
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066&cm_re=thermaltake_sata-_-17-153-066-_-Product
    which supports both 3.5" and 2.5" sata hard drives.
    Mar 20, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
    I can't copy files from my Seagate External Hard Drive. The light is blinking but I can't open the hard drive from my computer. Earlier I was able to see the files but I can't copy them to a new hard...
    Click "Safely Remove Hardware" in your tooltray (one of those little icons on the lower right
    of your screen across from the START button - its a green arrow over a PC board). That'll
    remove it from the system, then re-attach it (Windows Plug-n-Play will find it and re-mount
    the drive).
    Then, deep-scan your anti-virus software on your entire system - the possible cause of loss
    of directory structure on your external HDD.
    Then, run CHKDSK on your Seagate External Hard drive - to make the directory structure sane again.
    How-to-do-this: START> Run > (type in) chkdsk
    Then, download (free) "Recuva" software from http://www.piriform.com to recover anything lost in
    making your external HDD's directory/file structure sane again.
    Run Recuva in this mode:
    Recuva > Options (button) > Actions (tab) > Scan for non-deleted files (for recovery from damaged or
    reformatted disks)
    Feb 13, 2011 | Computers & Internet
    I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
    yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
    Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
    Hi there... suddenly my USB Seagate Barracuda 7200.11 External Harddrive is not working any more... unknown device is the message of windows (WINDOWS 7)! The mistake code is Nr. 43! Could you please help...
    Check that the power-brick is supplying power to the disk-drive.
    Check that the "data" cable between the computer and the device is tightly connected, at both ends. Try a different cable.
    Disassemble the casing, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer. If it is detected, then it is the USB-to-disk-drive adapter, inside the case, which has failed.
    Search online for a professional "data recovery service".
    For a large fee, they can repair your disk-drive, just long-enough to copy all your files to a working disk-drive.
    Aug 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
    Folder structure showing 0 files on external HD -after powersurge
    You may use data recovery software to see if you can rescue the files on your external HD.
    It may unable to recover all the files, but at least most of them.
    Sep 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
    Seagate Central STCG3000100 3 TB External Network Hard Drive - Black Logo
    49 people viewed this question
    Top Seagate Computers & Internet Experts
    Computer Links
    terminalcon
    John Anderson
    John Anderson
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
