Question about Miele Freezers
F1471 vi Miele freezer showing fault code 01 21 _F
Suddenly the unit started to flash a fault code 01 21 _F. What does that mean? I'm having problems with the ice maker and also, I changed the water filter around 3 months ago and it shows that it must be replaced. Any help will be appreciated.
    Problem Solver:
  • 14 Answers
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Posted on Nov 17, 2013
SOURCE:
VOTIT
  • 2071 Answers
SOURCE: everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Posted on Jul 30, 2008
duby1990
  • 370 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
bobicehouse
  • 1524 Answers
SOURCE: Kenmore refg. model # 106.56544400 ice maker
Water valve is a dual valve. One for water, one for ice. Switch the wires to test.
Posted on May 03, 2009
SOURCE: Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Posted on Aug 30, 2009
Testimonial: "Brilliant - it all makes sense now! I'm 100 per cent satisfied that is what it's all about. Many thanks, erkes. You're a star..."
SOURCE: Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Posted on Sep 04, 2009
Samsung RF260BEAEBC ice maker stopped working for 2 weeks. It just started working again. Have no idea why. How do I diagnose the cause?
Hello James;
My name is peter. I am a retired field service refrigeration technician.
It is not uncommon, especially with the flex mold type ice makers to have a ice cub jam the operation. I have gone on many a service call to find this the problem. I suspect over a period of time the vibration of opening and closing the bottom freezer door may have jarred it loose. Your rocker arm may also have been stuck.
It is not common but possible that the ice maker water solenoid valve spool may have been stuck. I would check this by gently tapping on the solenoid valve with a tool. It may have freed itself once again over time through normal operation vibration.
Jan 09, 2015 | Samsung RF260BEAEBC 25.5 cu. ft. French...
Ice dispenser not producing ice. water not being fed through pump to ice tray
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation.
Mar 20, 2011 | Freezers
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker broken
The ice maker likely needs replacing.
But ceck it to make sure its not hung up.
Does it have ice frozen in it or is it just turning arround.
Remove it and see if the heater underneath has a hold burnt in it.
Its just a plug in unit you can order one online.
Jan 13, 2009 | Freezers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
2,261 people viewed this question
Top Miele Freezers Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Miele Freezer Expert? Answer questions, earn points and help others
