Question about Seagate Central STCG3000100 3 TB External Network Hard Drive - Black
My Seagate Central will not power up
My Seagate Central 3TB will not power up and I would like to try recover the data. The drive will power up in an new external case, but Windows does to read the File structure. Is there a software or hardware solution to read the data stored on the drive?
  • 10 Answers
SOURCE: Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Posted on Oct 04, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 39 Answers
SOURCE: SEAGATE DRIVER ISSUE
It is a internal hard drive, which connects through IDE cable (the wide one), so you shouldn't be asked for drivers. If in any case you can't see this drive in your "My Computer" ("Computer" on Vista) it's probably because you have connected it wrong. Notice that the end of the IDE cable must be connected tou your main hard drive (where OS is instaled). If Seagate ST340015A is your main hard drive, than the end of the cable should be connected to it. If not, than on the same cable, about in the middle is another connection, you should use that one.
Posted on Mar 17, 2009
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
lserni
  • 466 Answers
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Posted on Nov 25, 2009
How can I get Windows 10 to recognize a Seagate 3TB External hard drive?
sorry but anything I tried with windows 10 failed and I went back to old OS thru the control panel and did a recovery .
Oct 27, 2015 | Seagate 3TB Expansion External Desktop USB...
Data Recovery Software
Maybe you can try uFlysoft Data Recovery for Mac, it can recover empty trash on Mac only in three steps:
Step 1. Launch the software to scan the device where your files deleted
Step 2: Preview the scan result files and make mark if it is the one you find
Step 3: Recover files
Mac Data Recovery Recover Lost Data with Ease
Jun 06, 2015 | Data Recovery Software Computers &...
Unable to download the Seagate Central NAS 1D driver on my Windows Vista desktop....help?
I think you mean hard drive. NAS devices aren't meant to be plugged into computers. They're meant for networks. NAS means "Network Attached Storage". There should be a disc that comes along with it to set it up. If you don't have one, you can connect to it through a web browser to set it up, thats usually how its done. If you look at the devices in your network, you should find its name, and then you can type in its name in a browser. As an example, if its name is seagate-nas, then you type "seagate-nas\" (without the quotes, and with the '\') into your browser and it should come up
Jan 12, 2015 | Seagate Central 3TB Personal Cloud Storage...
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
Need to install the hard drive from the Seagate Central into a computer to recover data.
Easier way if computer has USB ports, just use a USB convertor for IDE and Sata, (search for usb hard drive convertor) ( $10 or So) and you will be able to copy your files to the computer and to save to another hard drive or CD or DVD.
Apr 17, 2014 | Seagate Technology Seagate Central 4TB
Data recover seagate FreeAgent goflex 3Tb
If you run windows, go to:
Control Panel > Folder Options > "View" Tab > Check " View Hidden Files" & UnCheck "Hide Protected Operating System Files"
Then open your GoFlex and see what is in there.
Dec 31, 2013 | Seagate Computers & Internet
I HAVE LOST MY POWER ADAPTER FOR SEAGATE HARD DIK 3TB MODELLED SRD0072, I HAVE MY WESTERN DIGITAL POWER ADAPTER, CAN I USE IT WITH SEAGATE......
If the wattage is the same as the WD charger, and it fits then yes you can. You can order a replacement from Seagate directly @
(1.800.732.4283)
1.405.324.4700
8am - 6pm CT
Monday - Friday
Oct 20, 2013 | Seagate EXPANSION EXTERNAL DESKTOP DRIVE...
Seagate 3tb external hard drive gives beeping sound when powered on and not recognized by computer
There is a possibility that your hard drive has been physically damaged. I am saying this because unwanted sound and not being recognized are one of the symptoms of hard drive failure . So if the data is very important for you consult the data recovery specialist they will for sure help you out.
Feb 11, 2013 | Computers & Internet
Seagate freeagent goflex 3tb goes to sleep
It is probably not a problem with the Seagate. It is more likely the computer has turned off the USB port to save energy. This article is from HP but it should apply to your situation, follow the instructions. HP and Compaq PCs USB Devices Quit Working Unexpectedly Windows XP HP...
May 13, 2017 | Seagate Freeagent Goflex Desk 3 TB Desktop...
Seagate Central STCG3000100 3 TB External Network Hard Drive - Black Logo
166 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
