Question about HP iPAQ HX4700 Pocket PC
Can not detect sd card
I am sure that the SD card functions well. My device has already had hardreset. My 4700 cannot detect sd card at the first time I insert the sd card. Then, I take it out and insert the sd card again...After several times, my device do detect the SD card. when it detects sd card, It functions well with the sd card. If I take the sd card out, and insert again, I get the same problem. What happens to my 4700? What should I do?
  • pianojan Apr 03, 2008
    I am not super-savvy on these things, and don't even know how to format an SD card. I bought a 1GB SD card, and most of the time the hx4700 doesn't recognize the card. Even if it SAYS it's detected in the expansion slot (which occasionally it will after a soft reset), it won't give me the option of storing anything on it. For storage, it only states main memory (now full) or iPAQ store (now full). I have spent dozens and dozens of hours on this problem, and I'm totally out of storage/backup room on this thing. II did the SD renaming download, whatever that means, but no change, so I'm extremely frustrated. HELP!
  • 14 Answers
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Posted on Apr 10, 2008
Thank for your help,
I dont know why but, after I had my device hardreset (win2003se), it worked well. It runs very well without any problem from that time to until now.
Thank you again
Best regards
Posted on Oct 25, 2007
  • 490 Answers
Null
Posted on Oct 19, 2007
  • Anonymous Oct 19, 2007
    try the sd card in diff device like card reader or any other phone ..if same prob..take data back up and format the SD card.
SOURCE:
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
My PC won't recognize my SD cards
Just to be sure, it's an SD card (2GB or smaller) and not an SDHC card (4GB or larger)? If it's an SDHC card, is your card reader compatible with SDHC cards, or only with SD cards?
Mar 27, 2013 | Gateway Computers & Internet
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
My mother sends me a brand new samsung GT-15500 with a 2GB sd card but the camera is not functioning because it indicates that i must insert an sd card but i already inserted it in my cellphone but the...
Hi
Just restart your phone, and try again, when your insert your SD card your mobile is not detected. so its necessary to restart the phone
Jun 05, 2011 | Cell Phones
My lg kp500 wont detect my micro sd cards..already tried with several sizes between 1GB-8GB.funny thing is, they all work in my old phone(nokia). im sure i've installed them correctly. any ideas?
Your mobile doesnt support micro SDHC card, it supports only micro SD card, So check whether the card you use is SD and not SDHC
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Sd card is not working
Try cleaning the pins of SC Card with contact cleaner or alcohol if you prefer make sure its dry enough before inserting. If nothing happens try detecting it on PC Desktop with proper Card reader, backup files if you still can then reformat thE SD Card. Reinsert in your HTC G1 if successful reformat it again using your HTC G1 to acquire compatabilty on the device.. hope this help...
Jul 23, 2009 | HTC G1
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
HP iPAQ HX4700 Pocket PC Logo
3,247 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
