Question about Kitchen Ranges
We have a hood fan NexStyle and our lights have stopped working. We are looking to replace the whole housing for both lights On the housing the model number is YR-28B guartz lightstand max power 20W
Need a replacement light housing for hood fan. quartz lightstand model YR-28B
  • Edward Sauceda Oct 19, 2015
    Where can I get the replacement for lamp, housing and connection?
    New Friend:
Found it http://www.ebay.ca/ulk/itm/252138494486
Search under the model number YR-28B
Posted on Oct 23, 2015
  • 1 more comment
  • melissa phelps
    melissa phelps Nov 12, 2015
    Thank you! Hopefully they will ship to the US.
  • Fc1027 Nov 12, 2015
    Go to Ebay and search for YR-28B, shipping $15
    http://www.ebay.ca/itm/G4-Light-Housing-...
    Got mine from there ..fits perfectly in my range hood my lights are back working ..those G4 housing are hard to find. The Wire burns out.
Hi I have the same problem, did you find someone who sells the part?
Posted on Mar 15, 2014
  • Brian Andrade
    Brian Andrade Jan 04, 2015
    Same problem. Looks like cables melted or crumbled
  • melissa phelps
    melissa phelps Sep 28, 2015
    I have the same problem. Anyone find a replacement that isn't from China?
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Posted on Sep 02, 2009
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
SOURCE: Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Posted on Apr 26, 2010
SOURCE: All lights out on Faber Axia cooker hood
happened to me and I just cleaned all connections and it works!
Posted on Dec 08, 2012
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Why does my airvent whole house fan stop working intermittently?
if fan was able to run normally after a while, you may have problem with the motor starting capacitor, this gives the fan the needed kick to spin , when your fan stops working this may mean that the capacitor have already over heated, turning it off for a while will give it chance to cool off then start up again, have the capacitor checked and replaced immediately.
May 10, 2014 | Air Vent INC. 54508 36" Whole House Fan
I need a halogen bulb to replace the original one in my nexstyle range hood
So where do we buy the bulbs? We've been looking for ages. Thanks.
Sep 23, 2012 | Kitchen Ranges
We do not know how to turn the whole house fan on. Does it work through the thermostat on the walll for the air- heat switch?
To turn on your whole house fan, got to you thermostat. Open the door and look for where it says fan, most will have a selector switch to select "auto" or "on". You want it "auto for it to work properly with your furnace and or central air. If you flip it to "on" it will run 24 hours a day none stop, warning this may shorten the life of your fan a little.
Jul 29, 2009 | Ventamatic Direct Drive Whole House Fan...
Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Jul 05, 2009 | Kenmore 51840 Kitchen Hood
Hi, model Beta 900 Inox. There was a bang and now
it sounds like there is a short in one of the wires going to the fan be carefull not to dig into with power on (breaker) a wire may have come loose and shorted to the housing. look for a black soot mark and fused metal.
Jun 24, 2009 | DeLonghi (284748) Kitchen Hood
Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Jun 20, 2009 | Ventamatic Direct Drive Whole House Fan...
Range hood light switch not working.
you have checked the bulb? if so the the switch of disconnect from supply first and have a look at the condition of the switch it might be full of goo. joe
Nov 18, 2008 | Hotpoint  Standard Range Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen Ranges Logo
1,703 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
