Question about Samsung Audio Players & Recorders
My samsung HW-E5500 AV receiver displays protect mode when speakers are on
5 Suggested Answers
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
  • 92 Answers
SOURCE: goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
Posted on May 20, 2009
joe7379
  • 93 Answers
SOURCE: protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
Posted on May 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: When i hook my samsung
First, disconenct it and see if it can come up stand-alone.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 16, 2011
My NAD T747 keeps shutting down in Protection Mode at 6db when it used to go much louder. I cleaned the unit. Still nothing.
Modern AV receivers such as your NAD have protection circuits to prevent damage when there is a short on the speaker terminals. Look carefully at the speaker connections on the back of the AV receiver- for example, the speaker cable for front left speakers labelled + and - : there should not be any stray strands of wire that connect from + to - ; this would be a short circuit. Check each of the connections on the AV receiver as well as on the back of each of your Speakers themselves. Also ensure all connections are snug (do not use pliers). If this does not solve your problem, you may need to take your AV receiver on for a service checkup. Good luck !
Dec 12, 2014 | NAD Audio Players & Recorders
Connect speakers
All power amplifiers are designed to operate with a maximum current. This is limited by a minimum speaker impedance load. Your amplifier manual will specify the minimum load on output channels. High quality amplifiers can drive speakers with a combined impedance of 2 ohms or less. To calculate your parallel load, as you have requested, use the following formula. 1/Total load = 1/mgongo speaker impedance + 1/HW-E5500 speaker impedance.
Example. If your mgongo speakers have a nominal impedance of 8 ohms and the HW-E550 speakers have a nominal impedance of 8 ohms, then the formula is 1/Answer=1/8 + 1/8
1/Answer = 2/8
1/Answer = 1/4
Answer = 4.
If your amplifier can drive a 4 ohm speaker load without clipping then you are OK.
Dec 09, 2013 | Audio Players & Recorders
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
HW-E5500
This indicates a short in the audio output stage of the amplifier, check speaker wires for shorts, if okay! you will need to get the amp assessed.
Mar 22, 2012 | Computers & Internet
Pioneer vsx 515 overload and shuts down what can i do to fix this problem.
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the overload (protect) show or not . if not, then any of the speaker is damaged or you have to check the impedence of your receiver and speakers. It will be written on the rear side of both receiver and speakers in ohms. PIONEER recommend to connect 8 ohms speakers in to this AV receiver. If you are using 6 ohms speakers you have to do some setting in the AV receiver.For that do the following
1. With the receiver in standby, press STANDBY/ON while holding down the SPEAKER IMPEDANCE button.( Each time you do this, you switch between the impedance settings: )
SP 6 OHM - Use this setting if your speakers are rated at 6 Ohms
SP 8 OHM - Use this setting if your speakers are rated at 8 Ohms or more
You are not able to connect speakers with impedence bellow 6 Ohms with this receiver. Becuse the AV receivers impedence range is 6 - 16 Ohms.
If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Jul 27, 2011 | Pioneer VSX-515 Receiver
When i hook my samsung hw c500 home theater av receiver up to anything and turn it on, it goes straight into protection mode and shuts off. how can i get the protection mode to stop popping up so that i...
May 16, 2011 | Audio Players & Recorders
HW-C560S AV Receiver message display PROTECTION. I unplugged and plugged back in and still PROTECTION message. Is it time to take to shop? I know nothing about electronics.
Your set is in trouble my dear friend.
Protection will appear because the processor sense that you have a faulty parts on your unit.
To avoid further damaged, your system shut it off automatically.
The main reason is your Power amplifier I.C., it is shorted,need a replacement.
I"ve strongly adviced you to look for a qualified technician or electronic shop to fix your problem.
Good day!
Jan 02, 2011 | Samsung HW-C560S Theater System
Denon AV Receiver Model AVR3600 locked at'' Protection '' mode
The power supply is damaged and needs to be serviced. You have done exactly what you should have to test for an outside issue, it's the receiver.
Nov 02, 2009 | Audio Players & Recorders
Goes into protect mode..
May 17, 2009 | Sony STR-DG520 Receiver
Unit worked flawlessly 1 hour ago
Hi Ernietex,
Dont blame your wife.
Your receiver is basically going into protect mode.
The Denon AVRs contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
But, before you do than, please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If you still can’t resolve the issue yourself, try resetting the AV receiver/AV amplifier before going on to opening the Receiver.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Apr 20, 2009 | Denon AVR-2700 Receiver
115 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
