Question about Dewalt Saws
Why cant my dewal 876 band w cut in a straight line
4 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: cutting straight
No blade is going to cut perfectly straight. You have to adjust your fence for drift. Using a test piece of wood maybe 10" with a flat edge and marked to the width you want to cut work it into the blade about half way then stop your blade. Mark the edge where you are going to put your fence with a pencil. It will never be 90 degrees to the blade. Good luck. I use a Delta bandsaw and I do not use a metal clamp fence. I made my own fence that way I can clamp it where I want. You can find plans online to build one yourself.
Posted on Sep 16, 2009
  • 30 Answers
SOURCE: blade will not stay on cutting mark, even a
clean dust off the wheels, center the blade get it tracking and tension it so it has a medium high to (wide blade) high pitch (narrow blade) twang like a guitar sting when plucked with the saw turned off
Posted on Feb 20, 2011
  • 190 Answers
SOURCE: my band saw is BD
Ben-
You have two options, 1) increase the blade tension further, and 2) most the left guide block in closer to the blade. Overtightening the blade tension cause pull the wheels out of alignment, and cause blade drag, so keep this in mind. The guide blocks are also not designed to withstand lots of friction against the saw blade, nor is the saw blade going to tolerate much friction and heating up, so the guides should not be tightened snugly against the blade. Leave a small gap. Does this saw have guide blocks underneath the table as well? If so, adjust the left side block under the table.
Also, while cutting do not force the material into the blade. Apply just enough pressure to keep cutting, and let the blade set the pace. Band saw blades can wear rather quickly, so consider replacing the blade if the cute rate is getting very slow.
Has any of this helped at all?
Regards,
DIYpro
Posted on Jun 10, 2011
Band saw blade twists while trying to cut a straight line
The replacement blade could be defective.
Jul 30, 2016 | Blade Saws
Cant see m to cut in a straight line. when cutting a wine bottle the top it cutting straight but the bottom it not.
Cutting a glass on band saw is like cutting a metal. You have to make sure that you set up the band saw correctly, get a good quality blade, run on right speed, enough coolant and feed the material nicely.
Oct 21, 2013 | Saws
Blade is not straight is thier an ajustment
What do you mean? Is the blade itself is not straight when you install it or the blade is not cutting straight?
Jan 07, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Got a coronet band saw and it is not cutting true
I am not familar with the Coronet saw and there are alot of reasons your saw may not be cutting true.
- Mark a straight line appx. 1" from the edge on a 2 foot board, using the fence cut the board. Does it stay on the line? if not this is called "Drift"
-Most fences on band saws have a drift adjustment. To adjust mark a board the same as before but this time don't use the fence and saw it down the line about half way, turn off saw with the board in the saw, now slide the fence next to the board. you will see a gap on one end or the other adjust fence to the board(i.e. drift adjustment) now you saw will cut true.
NOTE- on saws that don't have this adjustment you may have to shim the fence to fit.
-If you go to You Tube and look up band saw set up they will cover this in detail.
I hope this helps
Shop Dog
Nov 18, 2010 | Saws
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
What is the Standard Setting to start with for a graphic equilizer
All the bands set to 0 or unity gain. Usually the faders have a 0 or marking showing no cut or boost on each band. This should be straight across and a flat line.
Oct 19, 2009 | Alesis iO 26 Sound Card
Cuts in circles,,even with new blade
The saw needs to have the blade guides adjusted properly. There are 2 sets of them . One above the table and one below. They may be solid pieces of steel or they may be sealed ball bearings They are the things that move in toward the blades sides to keep it tracking in a straight line. They need to come in toward the blade as close as possible without touching it. I set mine with a piece of paper as a spacer. set both sets like this and your saw should cut straight. Hope this helps you
Oct 18, 2009 | Delta 28-565 16'' Band Saw Blade 82'' x...
Cutting straight
this is usually caused by a dull blade or you need to carefully re-adjust the blade guides
Aug 12, 2009 | Ryobi 9 in. Benchtop Band Saw
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Cutting straight
The tension on the blade. the position of the guide rollers, and the condition of the blade are all important to get a straight cut. You might want to try lowering the guide rollers down close to the wood being cut. good luck.
Apr 26, 2009 | Ryobi 9 in. Benchtop Band Saw
Saws Logo
22 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
