Question about Music
Clavinova CVP-87a When I press the power switch it often happens that my digital piano (Yamaha Clavinova CVP-87a) doesn't switch on. Is there a possibility to repair this?
  • 1137 Answers
SOURCE: yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Posted on Oct 24, 2009
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Posted on Feb 27, 2011
SOURCE: yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Posted on Oct 10, 2011
sounddoctori
SOURCE: i need a replacement board XE771 for my yamaha clavinova cvp-20
406-582-5849 if you want to talk about it. I have one here and I'm repairing it. Maybe if yours has part of the upper surface intact I can figure out how to fix mine from yours and fix yours at the same time and test it here
Posted on Jul 20, 2012
How do I remove the top cover of a Yamaha Clavinova, CVP 30 digital piano?
There are 2 possible things to look for - can't remember due to age of your instrument.
Look under the piano - about 20cm in from front corners, can you see a screw head set in a metal bracket. If so undo these and the top cover / lid will lift.
If not try : Close cover over keys, get a torch and look above the cover through the slit to the far left and right about 10cm in you might see a screw head - under these (1L 1R ) lift top cover / lid.
I hope this helps
Dec 29, 2014 | Yamaha Music
HOW TO REPLACE CONTACT STRIP OF YAMAHA CLAVINOVA CVP 92 DIGITAL PIANO ?
Successful repair of my Yamaha Clavinova CLP 880
The principal to replace your contact strip will require one further step to that shown here where the customer has replaced the felts.
When you have the keybed out you will see the contact strip part 220. This is held in place behind the circuit boards. Remove boards, replace strip and reassemble.
It might be worth considering felts whilst you have the keyboard in bits as these wear out.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=19108
Aug 09, 2014 | Yamaha Music
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
I need a replacement board XE771 for my yamaha clavinova cvp-20
Apr 28, 2012 | Yamaha Full-Size Keyboard
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
Nov 17, 2009 | Yamaha Music
Yamaha clavinova cvp-83s
Oct 05, 2009 | Yamaha Full-Size Keyboard
Jul 21, 2009 | Yamaha Music
Music Logo
29 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
