Question about FreeMotion Exercise & Fitness
Freemotion treadmill stops
The belt suddenly stops on the treadmill
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Proform XP 650e Treadmill starts and suddenly
This condition is when the treadmill goes to full speed as soon as you power up the treadmill. Typically when this occurs, it is an indication of a short circuit in the motor controller.
Posted on Jun 29, 2010
  • 218 Answers
SOURCE: My question is, last night, I set the speed to
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Posted on Aug 11, 2010
  • 15 Answers
SOURCE: my freemotion treadmill is slipping,
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Posted on Oct 25, 2010
AJIN G
  • 6694 Answers
SOURCE: client run on treadmill then
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Posted on Feb 25, 2011
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
Belt front roller
please see the video attached, and proceed according. God bless you
Nov 28, 2013 | FreeMotion XTr Treadmill
Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
Dec 07, 2012 | FreeMotion 790 Interactive Treadmill
Freemotion xtr90 treadmill will start and run, but belt stops abruptly.
please LUBE the deck belt inmediately.
2) LUbe the rollers bearing too
3) test the input voltage motor , if there are the motor need repair.
4) Test the output motor board,if there are NOT voltage the board is faulty.
God bless you
Aug 26, 2012 | FreeMotion Xtr 90 Treadmill By Free Motion
How to replace treadmill running belt
First, you have to loosen the belt using the adjusting screws near the back of the belt assembly. Then you have to take the side moldings off.
Once the belt is totally exposed, you can take the belt off. Reverse the procedure to tighten the belt and align it
Aug 07, 2012 | FreeMotion treadmill t7.5
My freemotion treadmill is slipping, what can I do?
Oct 24, 2010 | FreeMotion Treadmill t7.3
Belt stops when I get on machine
well see if there is any adjustment on the belt attached to the motor that drivens the belt, if there is, try to loosen it a little bit.
see if this will solve the issue
Oct 31, 2009 | Nordic Track Nordictrack 9600 Treadmill By...
Exercise & Fitness Logo
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
