Question about Kenmore Elite 5-Quart Stand Mixer 400-Watt, White
Disassemble Has erratic speed suspect a sensor or speed control how do you take this apart?
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer runs only on slow speed
The Kiichenaid mixer has a centrifugal speed governor. I suspect your is stuck. It will need to be disassembled, and inspected.
Jun 28, 2012 | KitchenAid Food Mixers
High speed all the time
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204525.pdf
It is either the hall effect sensor item #9 or item #8, the speed control circuit board. Both can be found on ebay, the sensor for around $5 and the board for around $30. Unfortunately there is no simple test for either part.
Take the machine apart and look at the board where the control know is mounted to see if there is anything obviously cracked or broken. If the mixer was ever dropped on its side this could happen!
Apr 14, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
How do I replace the Speed Control Knob on the K5 Kitchenaid Pro
Hi PETER, Happy New Year! Your Speed Control Knob can be replaced quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty.
Before you start taking your mixer apart, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Your speed control assembly is attached to the bottom of the top part of the mixer’s head (or Illus. No 1, Gearcase Motor Housing, on pgs 4 & 5).
Turn to pages 6 & 7, titled: “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixers electrical components, along with all the parts. Locate lllus. Nos. 1, 2, 3, 4 - Pivot screw, Spring Washer, Switch Lever and Stud, and Control plate spring, respectively, which is the speed control handle assembly and Illus No. 5 and 6 - Speed Link & Cam and Flat Spring. Carefully inspect these parts to see if they have not come loose, particularly the Pivot Screw and Spring Washer. Also check to see if the Speed Link & Cam hasn’t shifted from its position. You should be able to see if something just needs to be tightened or if parts need to be replaced.
Also, with your mixer apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Jan 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My mixer master (Accolade 400) will only run at top speed
Hi JENNY, Merry Christmas and Happy New Year! Do not despair; there is a way to fix your KA mixer. From the symptoms you’re describing is sounds like your mixer’s (speed) Control Assembly and/or the Hall Effect Sensor has gone bad and either one or both parts need to be replaced.
As your mixer is out of warranty, the inspection and troubleshooting of the control assembly is something you can do yourself, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer.
If you're lacking one, you can download it from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home
Click on Customer Care>Locate Manuals & Guides, and enter the 6 character model number, in this case, KN15E1X, and then select the first file, KN15E1XBW0.pdf (335.24 KB) that appears under Parts List (17). (check to see if this matches your mixer model).
Turn to pages 4 & 5 titled, "Case, Gearing and Planetary Assembly", which provides an exploded view for the assembly and disassembly of the mixer and locate Illus. Nos.8 & 9, Control Assembly and Hall Effect Sensor, respectively. I suspect one or both of these parts that are the cause of your mixer’s speed woes. Since the (speed) Control Assembly is the more complicated of the two, that’s where I’d focus my attention. The Hall Effect sensor is a very simple device and rarely goes bad.
First check to see if any of the connections have come loose from your Control Assembly. If everything looks tight then you need to replace it. Unfortunately the whole controller assembly is on a little PC board filled with resistors and capacitors, which was not meant to be 'home fixed' and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not. Or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! – hslincoln
Jan 04, 2010 | KitchenAid 400 Watts KN15E1X Accolade 400...
Hello, When my wife puts the speed control to the low settings the speed is not low. It speeds up and slows down in waves and then continues at just the high speeds. What's going bad and can I replace...
Hi MIKEY, Merry Christmas and Happy New Year! By the symptoms you are describing one or two possible electronic components to your wife’s mixer are going (or have gone) bad. The good news is that, with a little effort, you should be able to repair the mixer yourself.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website a http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case KSM150P and select the next to last file KSM150PSWH0.pdf (773.44 KB) (it’s the white model that all…) listed under Parts List (61). (Verify that it matches your mixer model).
This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to pages 8 & 9, titled: “Motor And Control Parts” and locate Illus. Nos. 28, 29 and 30; Control Plate Assembly; Governor Assembly, and Phase Control Board, respectively. I suspect your mixer’s erratic behavior is being caused by one, or more of these components going ‘bad.’ Inspect all your connections to Control Plate Assembly from the Phase Control Board to see if one hasn’t come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing. And although the Governor Assembly is a mechanical device, if something is loose or broken on it that may also be a contributor to the mixers malaise.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. If you clear the lubricating grease from your mixer, you’ll need to replacethe grease with a ‘food grade grease’ (although I’ve seen automotive bearing grease used. - your call.) Prices can vary widely between vendors, so do your comparison shopping.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair and reassemble your mixer.
If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer run on high
Hi, RHASKEY. You don’t say what your model is, which would be most helpful, so I’m going to assume you’ve got one of the 6 qt Solid State mixers, models KD2661-3, KT2651-3 or KP2671-3 (an Epicurean or variation) or one of the 6 Qt. Professional 600 Bowl lift version like a KP26M1X model. Of course I could be way off base, too, so bear with me. BTW, the Hall Effect “switch” and Hall Effect “Sensor” are synonymous.
The Hall Effect sensor detects the rotation of the motor and limits the motors speed based upon your Selector switch lever setting. We don’t need to go into electromagnetic theory here, but it’s a pretty simple sensing device so I would suspect it’s not the cause of your problems. The Hall Effect Sensor feeds back to the (speed) Control Assembly and from your description of your mixer’s symptom’s I would say the signal is getting corrupted within the Control Assembly; hence the intermittent and erratic running.
The Control Assembly is a little PC board fabricated with numerous electronic parts; the more components the higher the probability one of them will go bad, for whatever reason. My recommendation would be to replace the Control Assembly board, but you can always order and replace the Hall Effect Sensor, too… We’re only talking a couple of dollars difference in parts.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number and select one of the files listed under Parts List (check to see it this matches your mixer model).
After you’ve removed the Gearcase Motor Housing (mixer head top half) look where the Speed Control knob is attached. This will be the Control assembly. Inspect all the connections to see if a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board filled with resistors, capacitors and diodes, which was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not or you can just order replacement parts without the testing.
As far as KA replacement parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
While your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Dec 18, 2009 | Food Mixers
Speed control faulty , only runs on 8 to10 speed.
Hi, RYLAND. You’ve assessed the problem, now you need to disassemble your mixer and replace the faulty control assembly. Unfortunately since you did not provide any model information, I kind of limited in what I can provide you for an answer, so I’ll give you a ball park answer. You suspect your problem has to do with the speed control assembly or governor assembly inside your mixer’s head and this is something you can fix this yourself.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select a file listed under Parts List. Some models will have multiple files. Download one and check to ensure it matches your mixer model. If it doesn’t download another until you find the correct manual.
Depending on your model, locate the Governor Assembly and Control Plate Assembly Turn on the pgs. titled – Motor Control Parts, or Control Assembly on pgs. titled – Case, Gearing and Planetary Unit. The illustrations provide an exploded view for the disassembly and reassembly of your mixer’s components, along with all the parts.
First inspect around the controller assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
Nov 21, 2009 | Food Mixers
Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixer speed turned erratic!
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Nov 22, 2008 | KitchenAid KSM50PR Professional Series...
Kenmore Elite 5-Quart Stand Mixer 400-Watt, White Logo
19 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
Darial Jr Lasaria
Darial Jr Lasaria
john h
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
