Question about Garden
Honda izy hrg465c3
Hi, mower has started as it should for the last 2 years without fail, however this morning, started mower and the auto choke would not disengage. it was chugging on choke for about 2 mins, would not run properly. switched off, left it for 30 secs then tried starting again. this time it started as it should & ran correctly. anyone know if this a problem that will get worse, also any cure for this prob. thanks, steve
  • 4,018 Answers
Clean the auto choke they do start to stick over time even just spraying some carb cleaner in the air intake with the filter of can clean it.
Posted on Jul 20, 2017
KMusselmann
  • 247 Answers
SOURCE: Fuel flow on a Cub Cadet 2165 Tractor
Jim. It is probably the jet is clogged or the float might be stuck.Pull the bowl off of it and inspect.
Or try carb cleaner from the auto parts store
Kurt
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
SOURCE: Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Posted on Jul 25, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
  • 18 Answers
SOURCE: Honda HR 17 lawn mower dies after it starts
01 Fuel tank cap? Loosen it to see if it is plugged.
02 Possible fuel line obstruction? Disconnect at carb to make sure there is adequate fuel flow.
Posted on Apr 20, 2010
B&S one start pull take numerous pull to start
If it is system I am thinking about it does have an automated choke system and that it is out of adjustment
Jun 03, 2015 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
After running, when shut down for just a few minutes, won't start. Has to sit and get cold in ordrer to start.
Check for spark when this happens. What I suspect is a failing ignition coil due thermal breakdown. I have had mowers run an hour or so to quit firing after taking a short nature break.
Mar 20, 2015 | Garden
Why won't my newer mower cold start?
Yup.. Expensive machine. All plastic housing. I bet you thought you bought the Cat's Meow. Lots of headaches with this machine... Wait until the Drive cable breaks. AND it will
May 04, 2014 | Honda HRX217VKA Lawnmower
Honda izy self propelled auto choke,the problem is the auto choke,it takes sometimes about five minutes to switch of,then when i stop the machine and start it again..say after about five minutes choke...
This is controlled by a thermostat next to muffler that is connected to choke. These thermostats often fail. They are not that hard to replace though. I never liked the design of these from the start. Should be easy fix though. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 18, 2013 | Garden
Honda izy Hello, The handlebar on my honda izy
If you never intend on loosening the handle bar to fold it u0p then go out and buy two nuts ( probably 1/4-20 or 12 mm) and tighten it all down with a wrench
Aug 16, 2013 | Garden
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Jul 10, 2010 | Garden
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Cold start problems with 1987 honda accord
I have an 87 accord manual carbureted with 200k miles on it and mine has done that ever since I got it. I've owned it for about four years now and the previous owner told me it happens. I have no idea what it means but the only problem I've ever had was when the alternator went out last summer (which I doubt is related but had similar symptoms).
Not a solution, more just commiseration.
May 29, 2008 | 1987 Honda Accord
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
