Question about Samsung Sony 16X IDE DVD-ROM Drive DVD Drive
Sony DVD Rom does not work...
I have a Sony DVD (internal) with my pc. When I put a cd in it will not auto. come up... but then when I go to run or other photo programs it will spin but not come up it says Insert disk into E drive... well it is already in there. I have tried taking it out and putting it back in. no luck... when I go to my computor then to devises with removable storage and right click on dvd (e) then go to properties then click on auto play it says music files when I change it then click apply then try again it still does not work, when I go back there it says music files again. I have updated the driver even though it says it is fine and working properly. What do I do now??? Please help me. thanks, renee'
    Scholar:
  • 116 Answers
IF you go to my computer or explore, and it does not work (EVER) then you either have a bad drive or bad controller.
More likely of the 2 is a bad drive. You can try a cd/dvd cleaning kit found at walmart, however it is unlikly that is the problem.
Posted on Oct 10, 2007
SOURCE:
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
Hello, I have Sony Vaio laptop model VGN-FS515, my internal cd -rom is not working, I've tried to reinstall computer's system from my external cd/dvd -rom, but can't do it because my BIOS doesn't support...
It sounds like you have done your homework, I suggest checking out ebay for a replacement for your CD-ROM, new would be better, but if you want to save money you might be able to scoop up a good used one at a cheap price.
Dec 19, 2010 | Sony VAIO Notebook
It works with CD-ROMs but when i put in a prerecorded DVD, it says "insert disk"
HI,INOUYE56,
THE CD RW/DVD ROM DOES NOT WORK BECAUSE ,IT MAY BE THE OPTICAL LANCE OF DVD ROM HAS BEEN DEFFECTED.FIRST YOU SHOULD PUT ANOTHER DVD DISK HICH ONE WORKS WELL IN ANOTHER PC.WHEN IT ALSO DOES NOT WORK PLEASE CLEANE THE DVD LANCE.IF IT WORK SAME AS BEFORE,YOU MUST CHANGE BECAUSE NEW VERSON DVD CD CAN NOT WORK IN OLD DVD ROM.IT IS THE SOFTWARE PROBLEM.
Nov 21, 2010 | Teac DV 28E Internal DVD Drive
MY ROM is a Sony (DDU1632C1) Internal DVD Drive. It doesn't read the DVDs and the CDs. I checked the data cable from the mother board and the power cable, cables worked for my CD rom but not the DVD/CD...
Check On the Back Off Your DVD-Rom itself look little pin with a black connector like a mini bridge... Look if it on position Master If So change your little connector to Slave Position.. The Restart your PC... Check also your IDE Cable for defect and all the pin inside your DVD connection ...Good Luck
Oct 09, 2010 | Sony (DDU1632C1) Internal DVD Drive
My sony cd-rom drive and dvd drive is giving me a a runtime error ! How can i fix this?
Go to your 'device manager' and remove the unit from the list - DELETE it - then - restart your pc and reload it in.
Gary
Jun 15, 2010 | Sony CDU5212 (dsso52xbkcdoem) Internal 52x...
When I insert cd or dvd my pc locks up sony dru 842a even when I run a system ck on this device the pc will lock up
The lens of your cd rom might not be crystal clear or it needs to be adjusted so change your cd rom or if you know an expert, tell him to clean its lens, check the internal software of the cd rom...
Aug 27, 2009 | Computers & Internet
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
Sony CD Rom Ccdu 5212 not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 25, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
Open Questions:
[email protected]#&^%~ AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
See all Samsung Sony 16X IDE DVD-ROM Drive DVD Drive Questions
Samsung Sony 16X IDE DVD-ROM Drive DVD Drive Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
