Question about Jacuzzi Home
Need teka undermount sink clips - Jacuzzi Home
  • 10865 Answers
SOURCE: Jacuzzi undermount sink
Your sink is clearly made to be undermounted. No trim ring available. With all of the choices now available for sinks and faucets I would recommend that the jacuzzi sink be removed and that you select a new sink and faucet set to your liking. good luck.
Posted on Jan 21, 2009
  • 659 Answers
SOURCE: Astracast sink has cracked
I'm not sure what your question is but if you are wanting to know if you can fix it, you are going to need to call Amercican Standard to see if there is a way.
Posted on Mar 30, 2009
  • 62 Answers
SOURCE: installing an undermount sink in case it need to be removed
under mount sinks are 'glued' to the underside of the granite countertop using clear silicone caulking. Clean both surfaces really good with alcohol or acetone (or even disc brake cleaner, apply caulking to bowl flange and position bowl up to underside of counter. Temporarily block in place and let cure for 48 hours. To remove bowl later, use a thin cutting blade like a hacksaw blade to slice through the caulking line. It helps if you don't squish all the caulking from between the bowl and the counter so that you can just get the hackwas blade in there in the future.
Posted on Jun 12, 2009
  • 24 Answers
SOURCE: I need to get a new stopper for my Teka sink
the average plug hole is 2" or 50mm any plumbing supply should help
Posted on Jul 22, 2009
  • 349 Answers
SOURCE: crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
Posted on May 05, 2010
HOW DO I SUPPORT MY UNDERMOUNT FRANKE SINK .THE INSTALLER FIXED THE SINK TO THE UNDERSIDE OF THE GRANITE WITH SILICONE . THE SINK HAS NOW LEAKED AND HAS DAMAGED THE CUPBOARDS .PLEASE ADVISE ,TO PREVENT IT...
How long ago was the sink installed?? It sounds like it was a faulty installation. Shouldn't the installer be responsible for fixing the problem??
How to Install an Undermount Kitchen Sink There should be retaining clips that hold the sink.
Apr 23, 2014 | Home
I need a cutout template for teka sink model 86555
If u have the sink. Put card board down for your pattern set sink on card board and trace sink .if no sink measure sink cut to size
Mar 31, 2014 | Trion Teka Sink 60 S Stainless Steel...
Can I drop-on this sink? or only undermount it? Thanks, Brooke
You are only restricted to undermounting these sinks because of there depth in relation to the siting of the tap, that's all. Remember if you place this sink on top you willhave to discreetly raise the tapbase fixing to maintain easy use of the taps
Jul 15, 2011 | Franke MHK-720-31-MB Fireclay Double Bowl...
I cant figure out how to use the clips for a Franke topmount granite sink. No instructions came with the sink. It is a formica countertop.
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
Aug 04, 2010 | Franke Home
Crack in farm house undermount sink Kohler
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Some padding under my undermounted sink has come off. What is it's purpose? and should it be replaced? Is it part of the undercoat?
The padding under the sink is just a sound buffer. If the sink became loud when the watter hits it just glue the pad back on and you will be go.
It is not part of the under coat.
Mar 16, 2010 | Franke RGX-170 Regatta Triple Bowl...
My undermount sink in kitchen moves back and forth, how do I stop it
If you look underneath you will see mettle mounting brackets with screws try tighten them up.If this wont work the hole might be too big you will have to take the sink up and put silicon or hard as nails under the sink plate
Oct 22, 2009 | NRS A.H. Undermount Large and Medium...
Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
Jan 21, 2009 | Jacuzzi Kitchen Iron Black Finish...
9 month old sink cracked, need to install new undercounter Kohler with clips. How hard is installation?
Not difficult. You can make it even easier by purchasing the undermount sink installation kit from Kohler. Good luck
Jan 11, 2009 | Kohler Caxton Undercounter Lavatory Sink...
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
