Question about Dishwashers
Defy dishmaid 3127/01 - Dishwashers
5 Suggested Answers
SOURCE: Defy Dishmaid Dishwasher (12 place), 2 years, 3 months old
Well, I fixed it in my case, by opening it up and taking a look. It seems that water was leaking out of the main compartment into the guts of the machine and shorting out a solenoid (I think). In my case, the water was leaking at the location where the 'water hardness adjustment' knob/screw is. This is in the middle of the left inside wall. (Take a look at your manual)
This may or may not be the problem in your cases, but it certainly produced the same symptoms. You need to be somewhat technically inclined to do this, and ABOVE ALL, make sure the dishwasher is off, unplugged and the water supply is turned off before going any further...
You start by taking off the top 'preparation surface' o the dishwasher by lifting two plastic clips at the back of the machine and sliding the top backwards and off. Next, by removing the left cover plate of the dishwasher (there are screws at the back, top and front of the machine), you expose a large flatish plastic device about 150x300x15mm that is responsible for dividing up the incoming water to add salt to one portion and then presumably recombine the water. This is held in place by two clips on the left side and the large ring around the water hardness adjustment screw on the inside of the machine. Twist off the ring and give the plastic thing a good pull to loosen it from the black tar-like stuff. Once it is free, you'll see a black o-ring that seals the joint between the plastic device and the main compartment. In my case, this was full of gunk and not sealing properly. I gave it a good clean and refitted the whole assembly. For good measure I also checked the clips securing the hoses connecting to the plastic device and made sure they were sound.
There is an electrical connection to what I think is a solenoid below the plastic device described above at the bottom of the machine. In my case, water was dripping down on top of the electrics when the machine took in water and I guess must have shorted out the solenoid, bringing the whole water delivery process to a halt. This created the mpression that the machine would fill up with water and go no further. I gave the whole area a good dry with a cloth. I also had to tilt the whole machine and allow the water that had, over the last few days acumulated inside, to drain out.
When everything was dry, I put back the cover plate, plugged the machine in and turned the water on and tested with a rinse, then a number 3 wash another three times. Everything worked fine.
Please be very careful when working with machines like this. Electricity and water don't really mix. I advise if you are not qualified that you ask a suitably qualified person to do the job for you.
Good luck.
Posted on Jan 18, 2009
  • 500 Answers
SOURCE: I have a Defy dishmaid
Hi Jacky Marcus,
Just keep the start button pressed in for about 5 - 10 seconds.
Should reset the cycles.
Hope this helps :-)
* If you found this solution helpful, please rate it
Posted on Jul 13, 2011
  • 15633 Answers
SOURCE: Defy Dishmaid model DDW144. Detergent dispenser continually caked up. Tried cleaning, drying, re washing. Problem continues.
Run it empty and if the problem persists then it is a plugged spray bar. If the problem goes away, try loading it so that the water is not hitting some item in front of the soap holder
Posted on Mar 11, 2013
SOURCE: my dishwashers thermostat has given in. Where can
Try RepairClinic.Com or PartsDirect.Com.
Posted on Oct 24, 2013
Require a wiring diagram for my Defy Dishmaid DDW140 dishwasher
here is a link to there manuals . Hope it is what your looking for.
Product manuals
Feb 27, 2016 | Cell Phones
What should the run time be for programme 2 on Defy Dishmaid?
Go by what they really know or if they steal
Dec 04, 2015 | Cell Phones
Defy dishmaid DW12
You have a major short to ground which is tripping the breaker. Get an electrician to check the machine, it may be as simple as you have trapped the cable. Don\'t mess with water and electrics. Electricity is the silent killer.
Aug 21, 2014 | KitchenAid Kitchen Aid Diswasher Part...
Mar 11, 2013 | Dishwashers
I have a Defy dishmaid 8, the programmes are all out, how can I reset the programmes?
Hi Jacky Marcus,
Hope this helps :-)
Jul 12, 2011 | Dishwashers
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
