Question about Murray Garden
Flywheel won't turn
Can't nanually turn flywheel
    Loyalty:
    Visited the website for 30 consecutive days.
  • Murray Master
  • 1,308 Answers
Motor may have seized or the brake is not released on the flywheel
Posted on Jan 17, 2018
If flywheel is put on wrong does it throug out timming
You can not put a flywheel on wrong, or the torque converter
in an automatic or clutch in a standard, won't line up
Also your engine won't start, as the crank position sensor
won't see #1 or any other cylinders
Timing is all done by the electronics, for the better part
of the last 30 years
Sep 07, 2012 | Cars & Trucks
Starter won't engage
check your flywheel & starter, one or both will be missing teeth, or the starter isn't "throwing out" yo engage flywheel
Aug 20, 2012 | 1989 Dodge Ram D-Series Pickups
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
Won't start been having trouble starting it a griding noise now won't start at all
Sounds like the starter on your car went out, when it makes a grinding noise ,
it's because the bendix or gear that engages the flywheel is worn , and is not
catching or meshing against the flywheel to turn it. if you are mechanicaly
inclined pull the starter off, take it to an auto parts store, most autoparts stores
have equipment to test the device at no charge, they can put a load on it and
tell you if its bad. just make sure to disconnect one side of the battery when
working on anything electrical. good luck!
Jun 25, 2011 | 2005 Kia Sorento
2000 Chevy s10 manual changed starter still won't start the starter is spinning but the engine won't turn over.
Do you have the correct starter and is it grinding, this sounds like a bad flywheel or wrong starter or even a bad one. look at teeth of flywheel and see if they are damaged. good day
Jun 19, 2011 | 2000 Chevrolet S-10
1993 gmc 1500 350cid - engine turns over but will not start. Fuel is good
Hello and welcome to FixYa!
If it's not turning over then the problem will be on the firing. If there's no current to the plugs, the engine won't fire up. Few things to look at to resolve the issue... First, the ignition coil can be faulty. Second, The ignition switch can be faulty. Third will be the starter. If it's faulty, it won't kick the flywheel. One good reason why it won't turn over.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 28, 2011 | 1991 GMC C1500
How to tune a sears chain saw that won;t stay running
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If no help, remove the flywheel cover and reset the ignition module pole clearance using a thin business card for a gauge. Turn the flywheel magnets under the module, insert the card into the gaps, loosen the module screws, and allow the module to contact the magnets through the card. Tighten the screws and rotate the flywheel somewhat to release the card, then turn the flywheel one full turn to make sure the gap doesn't close further. Try for spark at the plug--it should be blue, and snappy with a fresh plug gapped at 0.020". Hope some of this helps!
Aug 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Nanual
You can download the manual from the link below: http://h10032.www1.hp.com/ctg/Manual/bpy60536.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 10, 2007 | HP Photosmart 850 Digital Camera
Garden Logo
20 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
