Coleman Mobile Modular Home Electric Furnace Eb17 Eb17c Logo
A
Anonymous Posted on Nov 16, 2013
Coleman eb15b fan motor wont turn off - Coleman Mobile Modular Home Electric Furnace Eb17 Eb17c
william simpson
Level 3:
Genius:
  • Coleman Master 1,363 Answers
  • Posted on Aug 20, 2015
william simpson
Coleman Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
317644
Points
1636
Fan relay, capacitor,motor bad.
I'm having trouble with my blower motor On my Central Electric Furance
have to match horsepower,rpm,voltage, fan speed, rotation direction, and shaft size.
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Blower motor will not come on
If the blower motor has correct voltage and not running it can be a capacitor, its about $5 to try it, otherwise a new fan motor is required. 22296134-wil0gxehsfojcry3vcxysbjd-5-0.png
Coleman eb15b blower fan will not shut off
Hello, this will be a stuck relay for the blower. Trace wires back from blower motor and it will lead you to the culprit
1helpful
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
