Question about Ricoh FT7950 Copier
Ricoh error code sc 302 on ricoh ft7950 copiererror code sc aficio
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: Error code sc 387 on my Ricoh Aficio 4006
Helo Joe!
Clean charge corona unit and around the drum. If your problem did't stop you must replace the drum potential sensor.
Posted on Feb 23, 2009
  • 990 Answers
SOURCE: error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Posted on Feb 24, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Mar 31, 2010 | Ricoh Aficio 1035 Copier
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Error sc 302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
In English:
I would check the roller motor for a short, frayed, or damaged wires. Use a voltometer and compare the voltage to the cleaner motor.
Apr 27, 2008 | Ricoh Aficio CL3500N Laser Printer
15 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
