Question about Velocity Micro Cruz Reader R101 Tablet PC
Parse error wont install download
I cant go to the Google Play Store
hi there joe i want you first of all to check your internet connection if it is connected please check the storage or if the playstore is restricted in your country if not try uninstalling then re installing or do contact thier support center i hope this answer was helpful
May 24, 2016 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
Computer is not reading it now
plug it in and check under device manager if it is listed, it may show up with an error as unknown usb device, if so un-install the drivers reboot and plug it in again, if same error check with different lead. if still same errors download drivers and reinstall. if non of that works you may have a faulty conection socket.
Aug 29, 2014 | Kurio Touch 4S Handheld
I was trying to install games from my app store on my tablet why did parse error appear
I would recommend restarting your tablet and trying to redownload the app. Usually a a parse error occurs when there is compiling error with the package (app's data).
Essentially it might not have downloaded correctly so restarting the whole process should skip it right along!
Apr 08, 2014 | Tablets & eReaders
Cant download games from play store
please describe the issue. Is it not downloading the apps like the download bar is getting stuck or do you get an error message. Please be as descriptive as possible.
Mar 25, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Software updates
I would say you have registry errors. Run ASC from iobit and clear them then try again after a reboot.
Mar 17, 2014 | Iview 705nb 7" android netbook
Running application
delete application and download application again.
Jul 24, 2012 | Samsung Galaxy Tab 101 Tablet...
How to fix an android parse error
Upgrade it.Search it on Google, or call the supplier and see if they have good method.
Android 4.0 Tablet PC
Jan 13, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity Micro Cruz Reader R101 Tablet PC Logo
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
