Question about Cameras
My screen is greenand wont shut off - Cameras
2000 PANASONIC TV WITH RIGHT SIDE OF PICTURE THE GREEN AND RED COLORS ARE ABOUT A 1/4" OFF FROM EACH OTHER
trysetting the convergence on the tv itself,if that doesnt work you have a bad convergence amp maybe just 1 of them,you have 2 1 for greenand red 1 for green and blue,hope that helps.
Jan 17, 2013 | Panasonic Televison & Video
I have a single phase motor with 4 wires . blue,yellow/green,red and black .. how do i hook up to three wires ? black,greenand white?
the motor must be of the multi voltage type to start. 220/110 record the manufacture model# and name and check oline for the correct procedure for moving the wires to the correct pins. Or they may be a wiring schemadic on the inside panel of the motor cover that has the same info.
Dec 15, 2009 | Hayward 1.5 Hp Northstar High Performance...
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
My samsung lcd hdtv's tv picture seems to be greenand pink tones
Mainboard damaged and need to be replaced, if under warranty, call in for service, if not try ebay to get a general picture of price range.
You will need your product code to get the board and it is located in the back of the Tv, next to serial number.
May 17, 2009 | Televison & Video
My copmuter will not start up!
disconnect the wires and see the correct connection instructions of you motherboard Manual...
If it´s an Intel motherboard try to download it´s Pdf manual....very simple...Godd Luck!
Dec 05, 2008 | E-Machines T2596 CELERON 2.5 GHz 256 MB 60...
Laptop power light is on, wont shut off and screen is blck
You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
Try reinstalling the operating system to resolve this problem
May 13, 2008 | Dell Latitude D600 Notebook
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Printing a document
clibrite the printer cardige or take tisu paper & clean the cardige nozal & try to print
Feb 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
My headunit
I leaved mine like two hours in the telephone screen and then it whent its self out and works good now.
Apr 01, 2007 | Clarion DXZ555MP CD Player
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
